Staro 25.10.2005., 08:35   #1
Mailman
Mailman's Avatar
Postovi: 1,606
Radeon Omega Drivers v2.6.75 (Cat 5.10a)
What's New in Omega Drivers?
v2.6.75[*] Based on the Catalyst 5.10a Beta drivers.
[+] Added support for x1800 cards.
[+] Enabled Adaptive AA by default for x1800 cards, disabled for the rest.
[+] Added 1280x800 resolution for both laptop and desktop cards.[*] Reconstructed some tweaks to prevent any future compatibility issues.
[F] Fixed some minor resolution conflicts for laptops and integrated chipsets.
[F] Fixed a "Deja-Vu" problem in the installer related to Multires. =D
[+] Added the option to uninstall ATT, separate from the Omega uninstaller in the Start Menu.[*] Updated to ATI Tray Tools v1.0.4.780
http://www.omegadrivers.net/
Mailman je offline   Reply With Quote
Staro 25.10.2005., 16:17   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Izgleda da ga je opalila WoW kuga pa nije skužio da je bilo izašlo više verzija drivera-radi na tome da se to ispravi.
Tako da je preporuka malo pričekati.
"Sigh, knew it will not be that easy!
ATI changed TONS of stuff from the "027483" set to the "027483a" one, that means LOTS of work."
"Well, after 4 hours of work, I'm nearing finishing the new INF (btw, there are only 3 updated files in the "a" version, but the INF changed a LOT, and not only for x1k cards, but for a LOT of cards); I just need to add a few new cards that will be supported and then I can re-release."
Staro 25.10.2005., 17:30   #3
Mailman
Mailman's Avatar
Postovi: 1,606
opa, to nisam vidio...
postao sam ovdje sat vremena nakon što je "release-an" na Driverheavenu
Staro 25.10.2005., 21:40   #4
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
pa fora je bila u tome kaj je ati prvo aploudao pogrešnu verzinu 5.10a drivera
poslije su stavili pravu koja donosi dosta veliki skok u performansama u quakeu i doomu za sve grafe
pinsla je offline   Reply With Quote
Staro 25.10.2005., 21:45   #5
Mailman
Mailman's Avatar
Postovi: 1,606
Originally posted by pinsla
za sve grafe
ne samo za r5xx?
Staro 25.10.2005., 22:42   #6
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
A taman skino one na bazu 5.9 cat...sad cu opet morat skidat nove... sreca pa napokon imam flat
U biti...isplati li se to skidat za R8500? :confused:
Staro 25.10.2005., 22:59   #7
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Ne baš. Frend ima Radeon 9000 i novi driveri mu ništa ne donose.
Grafika mu je još očajna...
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 26.10.2005., 00:15   #8
pinsla
pinsla's Avatar
Postovi: 1,860
Originally posted by Mailman
ne samo za r5xx?
ljudi su javljali poboljšanja i za za R400 seriju posebno u quakeu
Staro 26.10.2005., 00:16   #9
pinsla
pinsla's Avatar
Postovi: 1,860
pa za 8500 se ne isplati skidat
barem što se performansi tiče
Staro 26.10.2005., 00:16   #10
pinsla
pinsla's Avatar
Postovi: 1,860
o čem ti pričaš?
kaj mu je očajno?
Staro 26.10.2005., 00:21   #11
domy_os
domy_os's Avatar
Postovi: 18,889
I meni na 9700 bolje radi verzija 4.9 nego bilo koja novija.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 26.10.2005., 01:08   #12
Jelc
Super Moderators
Postovi: 17,485
v2.6.75a
[*] Updated the OGL driver, this should solve some problems related to Quake IV.
[*] Updated the FireGL OpenGL driver.
[*] Updated internal settings for some Desktop, Mobility, Integrated chipsets and FGL cards.
[+] Added support for TONS of new cards (Desktop, Mobility, Integrated and FGL), including some unreleased ones.
[F] Fixed installation support for some cards. If you had problems installing the Omega Drivers drivers before (being it laptop or desktop), try now and let me know if something still broken.
Clarification:
I added AAA support for ANY card r300 and over, but is disabled by default (except x1k cards), so you only need to enable the AAA option in ATT and you are good to go.
Ovo je jako brzo riješeno
Staro 26.10.2005., 01:43   #13
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
Ma ne treba meni vise fps-ova kad stavljam nove drivere. Samo me zanima dal ispravljaju neke bug-ove... recimo quake4 mi je zelen...sve zeleno ... a u CoD-u se dogodi da texture letaju ili da slika bude skroz zrnasta (bez onog zamagljivanja u daljini...vec je sve iste ostrine).
Staro 26.10.2005., 10:48   #14
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
o čem ti pričaš?
kaj mu je očajno?
MadBoy je pitao isplati li mu se skidati nove drivere za Radeon 8500, a moj frend ima Radeon 9000,znači grafičku iste generacije.Njemu ne donose novi driveri ništa,niti više FPS-a,niti ispravljene bugove (jer su zatu seriju stvari već odavno ispravljene). Ja sam odgovorio na njegovo pitanje hoće li mu novi driveri donijeti neko poboljšanje i da li se isplati downloadati nove drivere,a odgovor je-ne
Staro 26.10.2005., 14:22   #15
pinsla
pinsla's Avatar
Postovi: 1,860
ne nego si lupio da je grafika očajna kaj nema veze s ničim
naravno da novi driveri ne donose ništa toj seriji već dugo vremena ali te grafe još uvijek dobro rade
ak moja 7500 prastara šljaka ko bog ne vidim zakaj nebi 8500
Staro 30.10.2005., 12:19   #16
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Ne vidim zašto i starije grafičke ne bi profitirale?
Kako su npr problemi (eventualni) sa Quake 4 mogli biti ispravljeni prije nego je dotična igra izašla?
Staro 30.10.2005., 12:54   #17
domy_os
domy_os's Avatar
Postovi: 18,889
Kakve to ima veze? Meni Battlefield 2 bolje radi s verzijom 4.9 nego 5.9, a za vrijeme izdavanja verzije 4.9 nije ni postojao Battlefield 2.
Staro 30.10.2005., 13:59   #18
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
A kako ti radi Stronghold 2 pod Windows XP Professional x64?
Ili Terminator 3?
Lineage 2?
DAOC?
Ako tebi sve radi najbolje pod 4.9, onda ko što bi ameri rekli "more power to you", al nije to sveto pismo
