Staro 05.05.2015., 13:22   #1
Zagorhac
Lokacija: Zagorje
Postovi: 421
(riješeno) MPC i interpolacija
pozz
istalirao sam MPC preko koje gledam televiziju (usb dvb-t). veceras je tekma i volio bih je gledati u 60 fps-a. kako to sloziti? probao sam preko SmoothVideo Project (SVP), ali mi rusi MPC. probao sam i samostalno sa instaliranjem avisynth-a, ali skripte koje nalazim zahtjevaju dodatne pluginove koje ne mogu naci za skinuti.
znam da je ovo sto pokusavam moguce jer sam davno prije vec takvo sto napravio preko nekih tutoriala. te tutoriale vise ne mogu naci, svugdje se spominje samo taj SmoothVideo Project (SVP) kojeg ne zelim.
zna li itko kako namjestiti avisynth i MPC (media player classic)
EDIT: nasao!
1. install ffdshow x32
2. instal MPC x32
3. Get Avisynth
4. Get mvtools
5. Download MT (multi-threading plug-in) for AVISynth
6. Don't delete or replace any files you have just encase you want to go back
7. Download this http://www.spirton.com/uploads/60FPS/Files-20110722.zip
8. Extract the tools\avisynth_plugin folder to your avisynth\plugins directory
9. Extract the fftw3.dll and avisynth.dll (okay to replace) into your C:\windows\system32 or sysWOW64 (for 64-bit) directory
10. Use this code:
svp_scheduler=true
svp_cache_reduce=true
svp_flow_lib="C:\Program Files (x86)\Avisynth 2.5\plugins\libflowgpu.dll"
threads = 8
SetMTMode(3,15)
V = ffdshow_source()
SetMTMode(2)
super =V.MSuper(pel=1,hpad=16,vpad=16)
backward_vec = MAnalyse(super, blksize=16, isb =true, chroma=false, searchparam=1)
forward_vec = MAnalyse(super, blksize=16, isb =false, chroma=false, searchparam=1)
V.MSmoothFps(super, backward_vec, forward_vec, num=60, \
den=1, blend=true, algo=23)
GetMTMode(false) > 0 ? distributor() : last
sad gledam bilo sta u 60 frame-ova i jedva cekam tekmu na planet tv...
Zadnje izmijenjeno od: Zagorhac. 05.05.2015. u 14:35. Razlog: nasao odgovor na upit
Zagorhac je offline   Reply With Quote
