Staro 16.10.2005., 18:53   #1
paklenik
Lokacija: vodice
Postovi: 42
integrirana grafička kartica
imam p4vmm2 matičnu ploču, cpu 1,7ghz, 256mb ram, hdd 60gb ali je grafička kartica 32mb integrirana s matičnom pločom probo sam ubaciti drugu grafičku gforce 4 mx 440 64mb ali kad upalim komp ostane mi crn monitor, znam da treba negdje u bios_upoštelati ali ne znam gdje ima na dva mjesta nešto u vezi s agp - u
prvi
ambios setup- pci/plug and play setup
play and play aware o/s -------------- yes
share memory size ------------------- 32mb
primari graphics adapter ------------- pci
allocate irq for pci vga --------------- yes
pci ide busmaster -------------------- disabled
drugi
ambios setup - advanced setup
quit boot ------------------------------ enabled
1 boot device --------------------------ide-0
2 boot device ------------------------- flopy
3 boot device ------------------------- cdrom
try other boot devices --------------- yes
s.m.a.r.t. for hard disks -------------disabled
bootup num-lock -------------------- on
flopy drive swap --------------------- disabled
flopy drive seek ---------------------- disabled
password check --------------------- setup
boot to os/2 -------------------------- no
l2 cache ------------------------------ enabled
system bios cacheable---------------- enabled
sdram timing by spd ------------------disabled
sdram frequency ----------------------100mhz
sdram cas# latency------------------- 2.5
sdram bank interleave---------------- disabled
agp mode ------------------------------4x
agp comp. driving--------------------- auto
manuel agp comp. driving------------ cb
_________________________________
agp aperture size ---------------------64mb
auto detect dimm/pci clk------------- enabled
clk gen spread spectrum -------------disabled
hyper threading function -------------disabled
dali mi može neko reći kpoje postavke trebam promjeniti da bi mi druga grafička radila a kako da isključim integriranu grafičku ona je inače s3 savage 32mb
paklenik je offline   Reply With Quote
Staro 16.10.2005., 18:59   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Stvai na AGP.
Stavi NO.
Staro 17.10.2005., 23:26   #3
MentalHarikiri
MentalHarikiri's Avatar
Postovi: 2,560
disabled stavi, ovim ubiješ onboard VGA
ovo enejblaš
nebi bilo loše enejblat
ovo isto slobodno ubiješ
ako imaš DDR266 ili viši (a imaš ) stavi to slobodno na 133MHz
@Tor
zašto bi stavio NO na :
Staro 18.10.2005., 12:18   #4
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
@Mental
kaj se sa S.M.A.R.T.om ne gubi malo na brzini?
Staro 18.10.2005., 12:23   #5
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
da ali sa smartom dobijes to da mozes vidjetli koliko ti je vruc hard
.i.
Razer Blade 15
Staro 18.10.2005., 13:10   #6
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
to sam znao.
a bez smarta u everstu se isto vidi temp harda.
Staro 18.10.2005., 13:20   #7
atha
atha's Avatar
Postovi: 9,067
@ mental
ako je to enable-ano, irq ce ostati upotrebljen za staru grafiku, u ovom slucaju za integrirku, a sa "no" se irq oslobadja.
___________
Just atha
x
Staro 18.10.2005., 16:14   #8
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
A i koji če mu dodjeljeni IRQ za stvar koju ne koristi? Čisto za svaki slučaj.
