Staro 13.10.2005., 00:19   #1
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,129
Izbor najtiseg 8cm venta...
... ako netko ima volje poredat ova 4 komada od najglasnijeg prema najtisem ili jednostavno rec koji je najtisi (a da ipak ima neki pristojni protok)
Ventilator Arctic Fan 3 TC, 80mm
Ventilator Arctic Fan 3, 80mm
Ventilator Arctic Fan Pro TC, 80mm, 10-23dB
Ventilator,sharkoon,ledfanluminous,tc,80mm,plavi
Znam da ovi TC imaju varijabilni broj okretaja, ali npr. treci po redu se vrti skroz do 2500 rpm-a, to mi se cini malo bucno... Treba mi vent za ispuh, slozio sam prakticki necujnu kantu sa Taganom i-Xeye pa ne zelim da mi ispuh narusi tisinu... misljenja? Neka druga (ne preko 60kn) preporuka? Zahvaljujem i zivli!
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 13.10.2005., 00:23   #2
Postovi: 7,568
Preporuka:
Sharkoon Silent Eagle 8.9db za cca. 62 kn u Linksu ili 59 kn u Bingu. Vrti se na 1000 RPM-a.
Staro 13.10.2005., 00:37   #3
MRKONJA
M.U.P.
MRKONJA's Avatar
Datum registracije: Sep 2004
Postovi: 2,277
Originally posted by McG
Preporuka:
I nema nikakav protok.
Žicaj trekića da ti proda jedan panaflo
Ako već hočeš sharkoona uzmi SE2000
MRKONJA je offline   Reply With Quote
Staro 13.10.2005., 00:40   #4
Postovi: 7,568
Pa dobro, more i toga (SE2000), ali onda mu se buka poveća za cca. 10db.
Staro 13.10.2005., 00:52   #5
^SuperUnknown^
Prečupavi mod
Postovi: 9,129
Preporuka:
Hehe, znao sam da ce netko odmah spomenut njega Zato sam i nadodao naknadno onaj dio o solidnom protoku Hvala svejedno!
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 13.10.2005., 00:57   #6
^SuperUnknown^
Prečupavi mod
Postovi: 9,129
Nije da hocu Sharkoona, hocu neku zlatnu sredinu bez obzira na proizvodjaca Ovi Arctic Cooling mi se cine totalno ok za tih 20kn koliko kostaju, pa ako i fulam s njima necu puno popusit... kaj mislite? Totalno se nemogu odlucit... :confused:
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 13.10.2005., 00:58   #7
MRKONJA
M.U.P.
MRKONJA's Avatar
Postovi: 2,277
A kak bi ti protok bez malo buke
Uvijek ga se može smanjit ali 19db je skoro pa nečujno(Fleks tiho budi. )
Staro 13.10.2005., 01:04   #8
Postovi: 7,568
Znam ja da nema protoka bez buke. Vidiš da je lepo napisal da je složil skoro nečujan komp i da ne bi htel da mu neki glasni vent ometa tu tišinu. Zato sam napisal da je skoro 10db bučniji.
Staro 13.10.2005., 01:12   #9
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Znam da mi je neko reko da je ovaj AC 3 bez TC-a jako dobar vent, jako puse a i tih je...samo kaj mislim da je jedini problem kaj se moze staviti samo na ispuh...mislim moze i upuhivat al ce viriti van kucista puno (ako govorim uopce o modelu kojeg sam ja vidil:confused)
Staro 13.10.2005., 01:20   #10
^SuperUnknown^
Prečupavi mod
Postovi: 9,129
Da, istina je da je predvidjen samo za ispuh, a to meni i treba. "Problem" je u ovim nosacima motora:
AC-ovi tvrde da bas taj patent daje cooleru tisinu Mislim da ce bit ili taj ili takav sa TC-om, ipak ga TC moze spustit do samo soma rpm :clap:
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 13.10.2005., 01:27   #11
Vuco
Vuco's Avatar
Postovi: 9,505
Da, samo kaj ti to ovisi o njemu, dal ce ga spustiti na soma okretaja...kaj ak mu je senzor lud i pici ga na max?
Bolje ti njega sam spojis na 5 ili 7 V iako ne znam zakej jer je i na 12 V necujan...
Staro 13.10.2005., 01:46   #12
Brain32
Brain32's Avatar
Postovi: 498
Zemi si AC-a bez TC-a i spoji ga na potenciometar, kad ne delas nis zahtjevno opicis ga na minimum, i kad ti treba samo ga nafrljis a najcesce nam treba bas onda kad tak i onak frcaju meci na sve strane
Brain32 je offline   Reply With Quote
Staro 13.10.2005., 01:51   #13
^SuperUnknown^
Prečupavi mod
Postovi: 9,129
A kaj mislis o ovima:
Glacialtech Silent Blade BLACK, 80x80x25mm, 9dBA
Glacialtech Silent Blade proziran BLUE, 80x80x25mm, 9dBA
Gledam na Glacial web-u pa ih ima u 2 izvedbe:
Entering Bearing DC FAN
2-Balls Bearing DC FAN
Sta je bolje? Ovi se vrte na 1700rpm, a protok je tu negdje sa AC-om :confused: Za poludit Najbolje uzet od svakog po jedan pa vidit, tj. cut
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 13.10.2005., 02:24   #14
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Ovako,
AC fan 3 TC je tih kad se vrti na malom broju okretaja i protoka nema, na 12V je UŽAS, dere se al i puše.
Iz njega se siplati izvati lopatice i stavit na neki drugi sleeve bearong vent.
No u cjeloj priči ste zaboravili
Glacial Tech Silent Blade 80mm. 26kn , fino pušu i ok po tišini. Ve-mil
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 13.10.2005., 02:40   #15
Brain32
Brain32's Avatar
Postovi: 498
Ajd kad su vec ventovi, koju 92-ojku uzet, malo bi zmoddao svog Zalmana a treba mi i za ispuh na kojem mi je sad takodjer Zalman...
Staro 13.10.2005., 10:14   #16
domy_os
domy_os's Avatar
Postovi: 18,958
Ja imam 3 x Arcic Fan Pro TC. Jedan je s prednje strane, vrti se na nekih 1500 rpm, hladi diskove, a druga dva su straga na nekih 1000 rpm i mogu reći da su jako tihi i dobri za svoju cijenu.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
