Staro 13.12.2014., 13:20   #1
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
(riješeno) Firefox 34 greška s Flash Playerom
Ne mogu pokrenuti youtube video i slične stvarčice.
This plugin is vulnerable and should be updated.
Activate Adobe Flash.
Check for updates...
To mi izbaci kad želim gledati youtube.
Dok u Add-ons Manager FF-a piše
Shockwave Flash is known to be vulnerable and should be updated. Update Now
Shockwave Flash 11.7.700.202
Shockwave Flash 11.7 r700 More
Kada kliknem Update now izbaci mi ovo stranicu - https://blocklist.addons.mozilla.org...x/blocked/p178
Ili da pejstan s te stranice:
Flash Player Plugin between 11.0 and 11.7.700.169 (click-to-play) has been blocked for your protection.
Why was it blocked?Old versions of the Flash Player plugin are potentially insecure and unstable. All users are strongly recommended to update on our plugin check page.Who is affected?All users who have these versions of the plugin installed in Firefox.What does this mean? The problematic add-on or plugin will be automatically disabled and no longer usable.
When Mozilla becomes aware of add-ons, plugins, or other third-party software that seriously compromises Firefox security, stability, or performance and meets certain criteria, the software may be blocked from general use. For more information, please read this support article. Blocked on October 30, 2012. View block request.
Kada kliknem plugin check page. izbaci ovo:
Stanje Radnja Shockwave FlashShockwave Flash 11.7 r700ranjiv11.7.700.202
Instalirao sam flashshockplayer zasebno, ali ništa ne pomaže.
Kako da deinstaliram taj dodatak iz FF? Pa ga probam nekako novu veziju ugurati?
Zadnje izmijenjeno od: Red Worm. 13.12.2014. u 13:26.
Red Worm je offline   Reply With Quote
Staro 13.12.2014., 14:15   #2
Mikeyy
Postovi: 2,078
To ti izbacuje svaki puta kada izađe azuriranje flash playera. Samo idi na adobe stranicu, skini najnoviji i riješeno. Ako nećeš da se ubuduće zezas, ostavi mogućnost automatske nadogradnje uključeno.
Staro 13.12.2014., 20:39   #3
JozicA
Vozi Miškoooo!!!
JozicA's Avatar
Lokacija: Svuda okolo / EU
Postovi: 1,404
Autor Mikeyy Pregled postova
isti problem na Firefox i kod mene, ali meni kod instalacije Flasha izbaci plavi ekran, tj. srusi windowse, neznam ni sam sto sve nisam pokusavao, lijeka nema, pa kad gledam youtube koristim IE ili Chrome, tamo sve radi bez ikakvog problema
JozicA je offline   Reply With Quote
Staro 13.12.2014., 21:04   #4
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
Riješio! Deinstalirajući sve plugine od Adobe-a. I to dva puta preko Your Uninstalera. Pa nanovo sve instalirati što treba. Pa probaj i ti. Moža ti uspije.
Staro 13.12.2014., 21:48   #5
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,143
to blokiranje mi presmjesno ...
zasto starije opere i bilo koji qtwebkit baziran browser moze starije flasheve koristit ?
Why would you invite a mushroom to a Christmas party? He's a fun guy to be with.
Why do mummies like Christmas so much? Because of all the wrapping.
Why does Santa have three gardens? So he can "ho ho ho".
HumWeed je offline   Reply With Quote
Staro 14.12.2014., 02:02   #6
Mikeyy
Postovi: 2,078
Inače ljudovi, za YouTube vam ne treba flash.
Na poslovnom laptopu ga nisam uopće instalirao, nisam još naišao na neki problem u surfanju.
Staro 14.12.2014., 04:17   #7
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,143
treba jer html5 ne daje za sve klipice opciju HD reze
vec zakljuca na 480p ili manje
Staro 14.12.2014., 10:22   #8
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
a koristis (milujem kristalnu kuglu).......... chrome?
Staro 14.12.2014., 10:52   #9
Mikeyy
Postovi: 2,078
Ne, firefox.
Jedino gdje mi je falio flash su neki portali strani koji video u sklopu vijesti ne prenose sa YT nego valjda neki njihovi flash playeri, i za djecu za one portale sa flash igricama, ali i tamo čak neke rade bez flasha.
Staro 14.12.2014., 11:59   #10
Burko
Burko's Avatar
Postovi: 2,317
i nemas bas nigdje instaliran flash? ajd pogledaj u control panel, da se ne patim da dizem svjezu instalaciju jer imam tu par laptopa, pa bi bas mogao....
Staro 14.12.2014., 14:30   #11
Mikeyy
Postovi: 2,078
Ne, nova instalacija windowsa, samo FF instalirao. YT radi najnormalnije, nisam isprobavao ove HQ verzije kako je HumWeed napomenuo, možda to ne radi.
Imam Adblocker i Ghostery tako da to ubije većinu ovih flash reklama svakako.
Staro 14.12.2014., 17:58   #12
Burko
Burko's Avatar
Postovi: 2,317
radi, bas imam jedan lap od frenda, dignuo nov W7 sa driverima. mozilla gore, jubito, svaki video na pocetku izbaci da treba flash, ali nakon sekundu-dvije video krene .
ok, my bad, ocito da sljaka .
Staro 15.12.2014., 03:01   #13
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,143
onda koristi neki internalni plugin koji bundlaju sa instalacijom
Staro 15.12.2014., 18:54   #14
Mikeyy
Postovi: 2,078
Mislim da se onda samo prebaci na html 5 kada nemaš flash.
Staro 31.01.2015., 09:23   #15
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
Svaki čas, malo pa malo izbaci mi da moram dozvoliti Adobe flash da se pokrene na određenoj stranici.
Kako to riješiti?
Slika je ispod
Staro 31.01.2015., 09:42   #16
Mikeyy
Postovi: 2,078
Ili dozvoli za stalno ili meni se javlja mogućnost "Blokiraj priključak".
Ona lego kockica mi je prikazana na istom mjestu i kada je stisnem, imam mogućnost da blokira priključak. Sada mi je dozvoljen flash, pa možda treba biti dozvoljen.
Staro 31.01.2015., 18:20   #17
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
Pa kliknem Allow and Remember i opet me to traži!?
Staro 04.08.2015., 17:58   #18
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
Imam jedan problem s tim pluginima.
Evo slike, jel može tko dati savjet da ispravim ove greške. Hvala
Staro 04.08.2015., 18:23   #19
Postovi: 23,587
@Red Worm
To je poznati "feature" flash smetja, ako imaš x verzija stariji naprosto se pravi blesav i ne zapamti iako si tu opciju kliknio,
sve se svodi na to da te prisiljavaju da moraš imati zadnju verziju ...
a zašto ?
zato jer zadnje verzije "omogućuju" reklame u layeru poviše osnovnog videa koje (tako jasno) ne možeš eliminirati ... smeće reklamno i bezobrazno do bola.
Vidim da se tu vrti / pokušava instalirati najnoviji flash ali očito zapinje iz nekog razloga.
Pokušaj na netu naći standalone / offline installer s tim da trebaš dva, jedan je za IE a drugi je za FireFox browser.
EDIT: Napravi reboot, ako se pokrene neki od flash instalacija potamani je kroz Task Manager ili sl.
Na ovoj stranici imaš offline instalacije > http://www.adobe.com/nz/products/fla...ribution3.html
Zadnje izmijenjeno od: Nikky. 04.08.2015. u 18:32.
Staro 04.08.2015., 22:41   #20
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
Uredu, hvala na pomoći. Sutra probam riješiti stvar.
Pozdrav
Staro 06.08.2015., 18:37   #21
Red Worm
Plasticni kirurg
Red Worm's Avatar
Postovi: 1,214
Sve sam deistalirao što sam imao na kompu, pa stavi ovo što si mi dao.
I opet šteka sve, naročito na ovom portalu dnevno.hr
jel vama šteka taj portal ili to samo meni?
hvala
Staro 06.08.2015., 19:04   #22
Postovi: 23,587
Probaj ugasiti onu hw akceleraciju u postavkama flesh - a.
Staro 06.08.2015., 20:17   #23
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,102
1.) Najbolja opcija je staviti dnevno.hr na blacklistu i time si riješio više problema od samog Flasha
2.) Nije Flesh nego Flash
Uglavnom, probaj skroz deinstalirati Firefox i instalirati ga ponovno. Nakon toga instaliraj ublock (umjesto AdBlocka) pa provjeri kakvo je onda stanje.
Možeš eventualno još upaliti Electrolysis, opciju koju Firefox možda uspije baciti u 21. stoljeće među ostale moderne preglednike.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online   Reply With Quote
