Staro 12.10.2005., 00:18   #1
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Problem sa Seagateom
Danas malo čačkam po HD tune-u i skontam da mi seagate izgleda ne valja
Evo što kaže HD tune
Ovo mi kaže SeaTools,ali morao sam iči na generic test,dakle za bilo koji hard,kad idem na seagate test baci mi neku grešku i moram restartat na dugme,CTRL-ALt-DEL ne reagira.
"SeaTools Desktop v2.1.05
Copyright (c) 2004 Kroll Ontrack Inc.
10/11/2005 @ 11:59 PM
The following information has been generated by the SeaTools Desktop. Use this information to help you recognize and resolve potential data access problems in a timely manner.
System Information:
BIOS Date 08/10/04
Conventional Memory size 638 K
Extended Memory size 1016092 K
IO Channel type PCI
Drive Information:
DRIVE SIZE MODEL
1 80.02 GB ST380011A
Serial Number = 3JV5BPPS
Int13 Num = 81, PHYS CHS = 9729x255x63.
ParmTable CHS, Rsvd = 9729x255x63
PARTITION CYLINDER SIZE
# Type Start End MB
PRIMARY
1 NTFS 0 9728 80023
Diagnostic Results:
Drive 1 (ST380011A)
SMART Status Check Result: Unknown
90-Second Test Result: Passed
File Structure Test Result: Failed
Partition 1 (No Label) Result: Failed with critical Errors
Complete Surface Scan Result: Not Selected
S.M.A.R.T., (S)elf (M)onitoring (A)nalysis and (R)eporting (T)echnology, a built-in hard disk drive failure prediction method reports an 'Alert' if a problem has occurred. It reports 'Passed' if no problems are found and 'Unsupported' if a hard disk drive does not support S.M.A.R.T.
Diagnostic Summary:
System Memory Test Result: Passed
Drive 1 (ST380011A)
Recommendation:
If you are not experiencing data loss and SeaTools reports File System Structure errors, they may be caused by a lock-up or failure to shutdown Windows correctly. Many times, these errors may be repaired through normal system maintenance. If you are experiencing a hardware error, you should isolate the cause and replace the failing component. If you are unsure how to proceed with repairs, contact a computer professional. After completing any maintenance tasks, run SeaTools again to verify that all errors have been repaired. If errors continue to occur, the system may not be stable. Again, contact a computer professional.
Copyright (c) 2004 Kroll Ontrack Inc."
A evo što kažu na netu o tome ovdje
Probao sam formatirati ali opet je isto.Imao sam neke podatke na tom disku ali sam ih prebacio na hitachia za svaki slučaj.Dosad nisam primječivao neke probleme ali nisam tamo ni pristupao često.
Sad kad sam formatirao svaki put kad ulazim u windowse provjerava onaj chdisk taj Seagate.
ne znam što da radim,da reklamiram to,promam low level format ili što,ali na onoj stranici piše da je to hardwerske prirode pa pretpostavljam da format ne bi pomogao?
Sorry na dužem postu ali ne mogu krače
Staro 12.10.2005., 00:28   #2
Postovi: 7,568
Reklamiraj. Sigurno je sigurno.
Staro 12.10.2005., 00:57   #3
Veki-os
Veki-os's Avatar
Postovi: 3,996
Ma reklamirao bih ja al disk je kupljen u HG-spotu(nažalost nigdje dalje nije bilo) i več vidim njihovu reakciju kad kažem da grešku vidim samo u HD tuneu i Seatoolsima,"pa ako disk radi onda ne možemo priznati garanciju",joj samo da mi to ne kaže
A ništa,sutras ga nosim,reči ču da su mi nestali neki podaci ,da se javlja chdisk na startu,za te greške,ponjeti to na floppyu i tak.
Zadnje izmijenjeno od: Veki-os. 12.10.2005. u 23:38.
Staro 12.10.2005., 08:57   #4
mighty
mighty's Avatar
Postovi: 519
javlja mi istu grešku u HDtunesu al se ništa ne zablokira. i ne pali se ch disk na startu
mighty je offline   Reply With Quote
Staro 12.10.2005., 11:49   #5
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,506
E Vedrane, to isto ti javlja onom liku na Seagateu 120GB što sam mu radio komp neki dan...
BTW, ne pomaže ti low level format, radio sam to na onom hardu.
Staro 12.10.2005., 19:58   #6
4444josip4444
4444josip4444's Avatar
Datum registracije: Sep 2004
Lokacija: VG
Postovi: 846
Skroz mrtav hard se lako zamjeni.... nije dobro reklamirat skoro pa ispravan proizvod....
4444josip4444 je offline   Reply With Quote
Staro 12.10.2005., 22:02   #7
Veki-os
Veki-os's Avatar
Postovi: 3,996
A da,sad ču čekat da skroz rikne,napunjen podacima,baš si biser Ili je ispravan ili nije,nema srednje.
Staro 12.10.2005., 22:40   #8
Postovi: 7,568
Nemaš kaj čekati, idi nek ti daju novi i ne napuštaj dućan bez novog diska.
Staro 12.10.2005., 22:52   #9
Veki-os
Veki-os's Avatar
Postovi: 3,996
Predao sam ga danas na reklamaciju,sad ga moraju slat u Zg.
Staro 12.10.2005., 23:03   #10
Postovi: 7,568
Glavno da je reklamacija prošla, sad se jedino trebaš malo strpeti dok ne stigne novi.
Staro 12.10.2005., 23:35   #11
Crais
Crais's Avatar
Datum registracije: May 2005
Lokacija: Zgb - shpaolin
Postovi: 641
E, ne bi baš reko da to tako ide. Vrlo lako se može dogoditi da mu iz Zg vrate isti disk, i kažu da je ispravan.
Crais je offline   Reply With Quote
Staro 12.10.2005., 23:38   #12
Postovi: 7,568
Ak budu to rekli, onda su budale. Mislim da bu dobil novi disk.
Staro 12.10.2005., 23:40   #13
Veki-os
Veki-os's Avatar
Postovi: 3,996
A onda ču doči s jednom inspektoricom iz jedne državne ustanove
ozbiljno
Staro 12.10.2005., 23:51   #14
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
meni su davno to napravili tulci iz hgspota sa napajanjem, crko vent (konfa pod garancijom pa nisam mogo otvarat) i vrate ono vent ne radi a starom nasrali da imam problema sa strujom doma!?!
nakon toga, JA sam išo sa starim i dobih novo napajanje.
Staro 12.10.2005., 23:55   #15
Postovi: 7,568
Ako su ljudima u stanju ''prodavati'' takve gluposti, onda oni imaju ozbiljnih problema......Psihičkih, a kad ih dohvati neki razjareni kupac, onda i fizičkih.
