Staro 30.11.2014., 05:55   #1
tigerija
Datum registracije: May 2009
Lokacija: Koprivnica
Postovi: 263
(riješeno) PC freezups = BSOD => (hal+0x12A3B)
Najčešće kad mi je internet browser upaljen (koristim chrome).
Desktop se na sekundi dvije zaledi i onda sve ok.
Od danas počelo. Na kraju sam dobio BSOD.
Snimio sam danas Netlimiter 3 (mislim da je 3). Možda to ima neke veze. Čitao sam po netu.
Upravo pročistio računalo: evo statusa par minuta nakon što sam ga upalio: http://gyazo.com/7c5f523c72c0861517646ca63a310a39
Neka pomoć? Ideje? :S
Bio bih zahvalan.
Virus, trojan?
Ram? Kako da provjerim?
HDD? Kako da provjerim?
Šta drugo?
Neki savjet za system backup ili HDD backup? Ne razumijem se u backupe. Ako me netko može usmjeriti. Da mogu sve backup jer planiram i novi Hard Drive uzeti sad.
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sat 29.11.2014. 21:11:48 GMT your computer crashed
crash dump file: C:\Windows\Minidump\112914-28111-01.dmp
This was probably caused by the following module: hal.dll (hal+0x12A3B)
Bugcheck code: 0x124 (0x0, 0xFFFFFA8008B39028, 0xBE000000, 0x800400)
Error: WHEA_UNCORRECTABLE_ERROR
file path: C:\Windows\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
Zadnje izmijenjeno od: tigerija. 03.01.2015. u 12:32.
tigerija je offline   Reply With Quote
Staro 30.11.2014., 09:21   #2
Don Kihoty
Datum registracije: Apr 2011
Lokacija: Sisak
Postovi: 1,373
PC ti je overclockan? Vrati na tvorničke postavke.
Istestiraj RAM i HDD.
Napravi novu instalaciju.
Sjedni i plači.
Razmisli gdje ćeš nositi PC u servis na diagnostiku.
Don Kihoty je offline   Reply With Quote
Staro 30.11.2014., 12:01   #3
B(p)lenky
Lokacija: Stari Grad
Postovi: 88
Imao sam davno isti takav bsod i problem je bio u optici,u plextorovoj dvd przilici,kad bi je odspojio sve bi radilo bez problema.al probaj prvo vratit bios na tvornicke postavke i istestiraj disk i ram
B(p)lenky je offline   Reply With Quote
Staro 01.12.2014., 10:43   #4
tigerija
Postovi: 263
Nije OC. Sve je na tvorničkim postavkama.
Sad sam unistal Kaspersky. Mislim da sam BOSD dobio oba puta kad je Kaspersky Internet Security skenirao računalo. Deep scanning, nakon sat dva skeniranja kreš. U oba slučaja ako se ne varam.
Provjerit ću HDD i RAM. Mogao bi HDD biti :S . Nadam se da nije procesor.
Imam sliku BSOD. Kasnije uploadam pa stisnem sliku ovdje.
Probam sve pa javim. Hvala na odgovorima!
Staro 03.01.2015., 12:32   #5
tigerija
Postovi: 263
Ok, znači, čini se da su uzročnici problema bili:
Kaspersky antivirus koji je zblokirao računalo kod skeniranja. Program je skinut sa njihove stranice.
Netlimiter 3 koji je svako malo prištekao računalo na trenutak. Moj brat je potvrdio isti problem.
Probao sam i NetBalancer, ali i on zna nekad prištekati malo. Naime, ovo sam iskusio samo kad sam igrao neku video igru. Samo bi malo cuknulo ko da imam lagg.
Eto, možda ovo nekome pomogne.
