Datum registracije: Jun 2014
Postovi: 1
Mikrotik - MetroCarnet
Zelio bih spojiti više računala na net preko MetroCarneta. Gledao sam na netu i ima puno postova na tu temu ali ni jedna nema konkretno riješenje. Spajao bih se na MetroCarnet preko Mikrotik rutera. Napravio sam konfiguraciju prema objavljenim postovima ali mi ne radi. Molim Vas za pomoć Ovo je moj konfiguracijski file: # jan/02/1970 00:12:10 by RouterOS 6.13 # /interface bridge add admin-mac=D4:CA:6D:xx:yy:zz auto-mac=no l2mtu=1598 name=bridge-local /interface ethernet set [ find default-name=ether1 ] name=ether1-gateway set [ find default-name=ether2 ] name=ether2-master-local set [ find default-name=ether3 ] master-port=ether2-master-local name=\ ether3-slave-local set [ find default-name=ether4 ] master-port=ether2-master-local name=\ ether4-slave-local set [ find default-name=ether5 ] master-port=ether2-master-local name=\ ether5-slave-local /interface wireless set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=\ 20/40mhz-ht-above disabled=no distance=indoors l2mtu=2290 mode=ap-bridge \ ssid=MikroTik-C8E833 /ip neighbor discovery set ether1-gateway discover=no /ip hotspot user profile set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \ mac-cookie-timeout=3d /ip pool add name=dhcp ranges=192.168.99.10-192.168.99.254 /ip dhcp-server add address-pool=dhcp disabled=no interface=bridge-local lease-time=10m name=\ default /ppp profile set 1 use-encryption=no /interface pptp-client add add-default-route=no allow=pap connect-to=metronet.vpn dial-on-demand=no \ disabled=no keepalive-timeout=disabled max-mru=1450 max-mtu=1450 mrru=\ 1600 name=pptp-out1 password=kkk profile=default-encryption user=kkk /tool user-manager profile add name=gosti name-for-users=gosti override-shared-users=2 owner=admin \ price=10 starts-at=logon validity=5s /interface bridge port add bridge=bridge-local interface=ether2-master-local add bridge=bridge-local interface=wlan1 /ip address add address=192.168.99.1/24 comment="default configuration" interface=\ ether2-master-local network=192.168.99.0 /ip dhcp-client add comment="default configuration" dhcp-options=hostname,clientid disabled=\ no interface=ether1-gateway /ip dhcp-server network add address=192.168.99.0/24 comment="default configuration" dns-server=\ 192.168.88.1 gateway=192.168.99.1 netmask=24 /ip dns set allow-remote-requests=yes /ip dns static add address=8.8.8.8 name=metrodns add address=8.8.4.4 name=google /ip firewall filter add chain=input comment="default configuration" protocol=icmp add chain=input comment="default configuration" connection-state=established add chain=input comment="default configuration" connection-state=related add action=drop chain=input comment="default configuration" in-interface=\ ether1-gateway add chain=forward comment="default configuration" connection-state=\ established add chain=forward comment="default configuration" connection-state=related add action=drop chain=forward comment="default configuration" \ connection-state=invalid add chain=input protocol=gre add chain=input protocol=tcp src-port=1723 /ip firewall mangle add action=mark-routing chain=prerouting new-routing-mark=metrovpn \ src-address=!192.168.99.2-192.168.99.254 /ip firewall nat add action=masquerade chain=srcnat comment="default configuration" \ out-interface=pptp-out1 to-addresses=0.0.0.0 /ip route add distance=1 gateway=pptp-out1 routing-mark=metrovpn /ip upnp set allow-disable-external-interface=no /system leds set 0 interface=wlan1 /system ntp client set enabled=yes mode=unicast primary-ntp=161.53.123.5 secondary-ntp=\ 161.53.160.5 /tool mac-server set [ find default=yes ] disabled=yes add interface=ether2-master-local add interface=ether3-slave-local add interface=ether4-slave-local add interface=ether5-slave-local add interface=wlan1 add interface=bridge-local /tool mac-server mac-winbox set [ find default=yes ] disabled=yes add interface=ether2-master-local add interface=ether3-slave-local add interface=ether4-slave-local add interface=ether5-slave-local add interface=wlan1 add interface=bridge-local /tool user-manager user add caller-id=bind customer=admin disabled=no name=xxxx password=xxxxx \ shared-users=2 wireless-enc-algo=none wireless-enc-key="" wireless-psk=\ 102030 Zadnje izmijenjeno od: Nikky. 10.06.2014. u 14:23. Razlog: Maskirana mac adresa |
Postovi: 23,534
U oko mi je upalo da si postavio MTU=1450 a po ovim linkovima ispod trebalo bi biti MTU=1460 (mada nije sveto pismo), http://www.ubuntu-hr.org/forum/viewt...e87f0be8918661 čoek davno pitao ali nema krajnjeg rezultata http://forum.wifi.hr/mikrotik/rb-ppt...a-metrocarnet/ http://forum.wifi.hr/mikrotik/pptp-metrocarnet/ sudeći po prvom linku (ubuntu) treba se igrati sa rutama, vjerojatno u kakvoj skripti ... |
