Staro 28.09.2005., 14:59   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATI Tray Tools 1.0.3.750
Software highlights:
Support for ATI Control Center
Support for TV Out and displays with profiles
Options to change Theater mode together with TV Out
Overclocking with templates including FAN Control
Automatic overclocking when application required 3D mode
Temperature monitoring
Artifact Tester with ability to find maximum stable clocks for GPU and Memory.
Game profiles with desktop shortcut creation.
Direct3D settings with templates, GUI form and tray popup menu
OpenGL settings with templates, GUI form and tray popup menu
Hardware low level color correction
Hardware tweaks. Setting PCI latency timer
Radeon Information Show information about memory type, active rendering pipe lines and more
System wide Hot Keys. (Load profiles any profiles/work with colors/run any application)
Refresh Lock system with ability to set separate refresh rates for each resolution.
Tweak for overriding Pixel and Vertex Shaders
Speed improvement tweaks for Anisotropic/Trilinear Filtering. Support for Catalyst A.I.
Support for system options, VPU Recover, DMA Copy and so on
Support Display Rotation.
Support for MMC applications
Support for HYDRAVISION applications
Monitoring Graphs. (GPU/Env temperature. GPU/Mem speed, Main CPU Usage).
A lot of useful things. Like Save/Restore Desktop icon positions and more
Audio Recorder
Screenshots system
Powerful Plug-Ins support. (API for VC++/Delphi included)
PCI Register Set. Allow to program any registers in any PCI device at start up time. For advanced users only!
Source code for plugins as examples.
Supported OS: Windows 2000, Windows XP, Windows 2003
Windows 9x/ME is not supported!
http://downloads.guru3d.com/download...t=733#download
Staro 29.09.2005., 12:32   #2
Jelc
Super Moderators
Postovi: 17,485
Added support for Adaptive anti-aliasing mode. Substantially improves visual image quality by enabling supersampling anti-aliasing on transparent textures, and multi-sampling anti-aliasing on all other textures. This delivers exceptional levels of image quality, while maintaining very high levels of performance. (Only Catalyst 5.9 and up and only if supported by hardware)
Improved Adavanced Registry Editor
Added experimental tweaks database "Multi Thread Support"
Added small benchmark module (with ability to compare with predefined results from all popular ATI Boards) into Overclocking window. This benchmark use Speed settings for all Catalyst values like AA/AF and so on.
[F] Fixed error when ATT try to load unavailable color profile
Added support for X800 VE, X800 GT, X850 SE
[F] Fixed system resource leaks with HotKeys enabled
Updated list if supported SmartShader effects.
Updated internal Game Launcher. Now you can created two and more profiles for single executable file and run it from ATI Tray Tools tray menu or create shortcuts (from Game Profiles window) to apply different 3D settings for single game. If you start game as standard Windows shortcut or directly form any file manager, ATT still will detect it and apply settins regarding to the first found entry in list of registered games.
Added default 3D profiles in installation package
Improved I2C control functions
Added option to disable I2C control functions. No need in I2C if your board doesn't have temperature sensor.
Improved FAN control and FAN Duty cycle reading for ASUS boards.
Added temperature monitoring and FAN control support for Abit boards with WinBond sensor.
Now screenshots system can create jpg/png files even if there is no game is active.
Staro 29.09.2005., 19:27   #3
kiki89
kiki89's Avatar
Lokacija: n/a
Postovi: 228
jel se u tome programu moze namjestiti prozirnost taskbara i prozora? ako da recite mi gdje,a ako ne zanemarite ovaj moj post
kiki89 je offline   Reply With Quote
Staro 29.09.2005., 22:45   #4
illusion
illusion's Avatar
Postovi: 562
thx.... ovo mi je trebalo
illusion je offline   Reply With Quote
Staro 29.09.2005., 23:57   #5
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
ovo mi baš nije bistro
koje kartice to podržavaju?
i na koji način je to postignuto registry hackom ili?
videl sam da je humus bio nekaj slično izbacio ak se ne varam za transparentne teksture
pinsla je offline   Reply With Quote
Staro 30.09.2005., 00:17   #6
Jelc
Super Moderators
Postovi: 17,485
Imaš npr. DirectX Tweaker Public Beta 2/3 sa kojim si mogao i na starijim grafama uključiti do 4 X SSAA, ali samo u 1024x rezi.
Ovo je predviđeno za R5xxx seriju, možeš ga uključiti u registryu, u nekim igrama uopće nije tako jaki pad perfomansi, u nekima opako zvekne.
Imaš tu nekaj o tome:
http://www.rage3d.com/board/showthread.php?t=33830200
Staro 30.09.2005., 00:43   #7
pinsla
pinsla's Avatar
Postovi: 1,860
hm da ak ovo bude radilo dovoljno brzo na R5 seriji bit će to veliki plus i dobitak u kvaliteti slike
Staro 30.09.2005., 00:56   #8
Jelc
Super Moderators
Postovi: 17,485
Ja bum probao kad instaliram Omega 5.9-još ima 5.8 pa ne mogu na njima.
Staro 30.09.2005., 15:41   #9
Jelc
Super Moderators
Postovi: 17,485
Dakle prvo-Adaptive anti-aliasing mode, napravio sam registry "hack", morate imati ili funjavi CCC da bi uključili tu điđu ili tak jasno ATT (bolje ).
Ako imate samo CP onda kita labudova
Izgleda jako dobro.
Baš sam sad ponovno instalirao i Far Cry 1.3 pa ću probati i njega, HL2 ide super.
SS2 demo isto.
Budući da je uočeno par bugova sa novim ATT-om Ray je promtno izdao Bug Fix Build 1.0.3.755
http://www.radeon2.ru/atitray/attsetup.exe
Ako će biti još bugova-biti će rješeno za par dana-e to je pravi support , otkrije se koji bug, drugi dan izađe nova verzija...
Mali edit-igrao sam da sada Far Cry, izgleda odlično, jedino malo više zvekne frame rate nego u SS2 ili HL2. (4xAAA i 8xANISO)
