Staro 18.09.2005., 22:16   #1
XxX
XxX's Avatar
Lokacija: Grobnik
Postovi: 86
Program(pack) za instaliranje
Treba mi program s kojim ću instalirat više programa odjednom, kao neki one touch setup. Tako da odmah namjestim postavke svih programa i da samo instaliram sve preko jednog klika.
.::PCE::.Vlatko (nekad bio, šmrc)
XxX je offline   Reply With Quote
Staro 18.09.2005., 23:45   #2
mirkoB
mirkoB's Avatar
Datum registracije: Feb 2003
Postovi: 783
Ako si voljan učiti, dakle imaš nešto hakersko u sebi, za to ti nije potreban program. u Windows registryju postoji key koji se izvršava prilikom podizanja Windowsa. Tu se, uz pomoć manje-više jednostavnog batch fajla, mogu uglaviti silent instalacije gotovo svih programa.
Taj batch fajl izgleda ovako (primjer):
cmdow @ /HID
@echo off
SET KEY=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnceEx
REG ADD %KEY% /V TITLE /D "Installing Applications" /f
REG ADD %KEY%\005 /VE /D "Adobe Reader 6" /f
REG ADD %KEY%\005 /V 1 /D "%systemdrive%\install\AdobeReader6\AR6.msi /qn" /f
REG ADD %KEY%\010 /VE /D "Alcohol 120" /f
REG ADD %KEY%\010 /V 1 /D "%systemdrive%\install\alcohol\setup.exe /qn" /f
REG ADD %KEY%\010 /V 2 /D "REGEDIT /S %systemdrive%\install\alcohol\register.reg" /f
REG ADD %KEY%\015 /VE /D "Diskeeper 8" /f
REG ADD %KEY%\015 /V 1 /D "%systemdrive%\install\DiskeeperPro_8.0.459.exe /s /v/qn" /f
REG ADD %KEY%\020 /VE /D "DU Meter 3" /f
REG ADD %KEY%\020 /V 1 /D "%systemdrive%\install\dumeter3.exe /VERYSILENT /SP-" /f
REG ADD %KEY%\025 /VE /D "IsoBuster 1.5" /f
REG ADD %KEY%\025 /V 1 /D "%systemdrive%\install\IsoBuster1.5.exe /VERYSILENT /SP-" /f
REG ADD %KEY%\025 /V 2 /D "taskkill /F /IM isobuster.exe" /f
REG ADD %KEY%\030 /VE /D "Kerio Personal Firewall 2.1.5" /f
REG ADD %KEY%\030 /V 1 /D "%systemdrive%\install\KPF\Setup.exe -s" /f
REG ADD %KEY%\035 /VE /D "MDAC 2.7 SP1 Hotfix" /f
REG ADD %KEY%\035 /V 1 /D "%systemdrive%\install\mdac\mdac.cmd" /f
REG ADD %KEY%\040 /VE /D "MSN Messenger 6.1" /f
REG ADD %KEY%\040 /V 1 /D "%systemdrive%\install\MSN_Messenger_6.1.0202.msi /qn" /f
REG ADD %KEY%\045 /VE /D "Nero Burning ROM 5.5" /f
REG ADD %KEY%\045 /V 1 /D "REGEDIT /S %systemdrive%\install\nero\register.reg" /f
REG ADD %KEY%\045 /V 2 /D "%systemdrive%\install\Nero\Nero551054.exe /silent /noreboot" /f
REG ADD %KEY%\050 /VE /D "Importing Registry Tweaks" /f
REG ADD %KEY%\050 /V 1 /D "REGEDIT /S %systemdrive%\install\regtweaks.reg" /f
REG ADD %KEY%\055 /VE /D "Cleaning Up and Rebooting" /f
REG ADD %KEY%\055 /V 1 /D "%systemdrive%\install\cleanup.cmd" /f
EXIT
Ako te zanima ovaj način, pogledaj MSFN link odakle je ovaj primjer, ili pitaj konkretnije (koje programe i sl.) - radio sam ovakve stvari.
BTW na stranici s linka se spominje instaliranje programa kao dio instalacije windowsa, no nemoj da te to zbuni. Programe je na ovaj način moguće instalirati bilo kada.
| AVG Free 7 | SPF 5.6 | SS&D 1.4 | MBSA 2.0 |
| Firefox & Thunderbird 1.5 | MozBackup 1.4.4 | POPFile 0.22.2 |
| 7-Zip 4.32 | VMWare Player | nLite 1.0RC7 | Qemu 0.7.2 |
| PDFCreator 0.8.0 | Open Office 2.0 | Readiris Pro 8 |
| UltraVNC 1.0.1 | Media JukeBox 8.0 | Burn4Free 2.3 |
| Pentium D 805 | ThermalTake BigTyp 120 |
| Gigabyte G945P-S3 | 1024/667 Kingmax DDR2 | 160 GB Hitachi SATA2 |
| Enlight 430W | Antec Solution SLK3700AMB | OKI OL400w |
| XP Home SP2 zakrpan do jaja + Windows 98SE Virtual Machine |
| 178/81 |
| Cipele br. 42 |
| 35 godina |
mirkoB je offline   Reply With Quote
Staro 20.09.2005., 21:30   #3
XxX
XxX's Avatar
Lokacija: Grobnik
Postovi: 86
Ma samo mi treba za ove banalne programe jer mi se ne da sve pojedinačno instalirat kad stavljam nove windowse.
(BSplayer, nero, winamp, paint shop pro, diskeeper, winrar...)
Staro 21.09.2005., 01:00   #4
mirkoB
mirkoB's Avatar
Postovi: 783
Daj mi koji dan, upravo si reinstaliram stroj od nule, pa sam malo u ofsajdu.
Moram naći i provjeriti instalaciju svakog od tih programa, a to će potrajati.
BTW jesi razmišljao o Ghostanju? Složiš stroj kak ti paše, koristiš, recimo, mjesec dana da sve sjedne na mjesto i onda napraviš ghost image diska. Smjestiš image na CD-je (DVD-je) a kasnije se ne baviš reinstalacijom nego samo pukneš image natrag na disk. 15-ak minuta posla, a sve kako je i bilo.
| 178/81 |
| Cipele br. 42 |
| 35 godina |
