Staro 02.12.2013., 00:10   #1
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
(riješeno) Nerješiv problem sa Skypeom
Vec nekoliko dana imam problem sa skype te mi javlja ovo:
Skype has encountered a problem and needs to close. We are sorry for the inconvenience.
AppName: skype.exe AppVer: 6.11.0.102 ModName: skype.exe
ModVer: 6.11.0.102 Offset: 00212433
Probao sam SVE, potpuno uklanjanje skype-a koristeci Revo Uninstaller Pro. Ponovo sam ga instalirao no problem nije rijesen.
Verzija skype-a je 6.11.0.102.
Problem je frustrirajuci, ima li rjesenje ikakvo?Hvala!
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Traitorous_8 je offline   Reply With Quote
Staro 02.12.2013., 00:35   #2
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,567
Probao koju stariju verziju stavit?
Koji OS imaš?
Staro 02.12.2013., 01:43   #3
MMI
MMI's Avatar
Postovi: 913
ako si na xp mora biti sp3
MMI je offline   Reply With Quote
Staro 02.12.2013., 01:58   #4
Traitorous_8
Lokacija: Vž
Postovi: 81
Autor Juice Pregled postova
Koji OS imaš?
Hm, Win XP SP3, probao sam ali cim sam je instalirao odmah je pisalo da je najnovija. Sad vise ni sam nisam siguran da li je to prije ciscenja sa Revom.
Staro 02.12.2013., 04:23   #5
Traitorous_8
Lokacija: Vž
Postovi: 81
Autor Traitorous_8 Pregled postova
Rijesio sam downgradeom skype-a. Tipicno, umjesto da novijim verzijama poprave oni samo zeznu.
