Staro 16.09.2005., 22:40   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
VIA AC97 Vinyl Audio driver 6.20m
Danas samo lete friški audio driveri...evo i za VIA-u.
The latest audio driver for VIA chipset motherboards with integrated sound.
For use with the following Products:
VIA AC97 codec incorporated into VT82C686A South Bridge ( VT82C686A )
VIA AC97 codec incorporated into VT82C686B South Bridge ( VT82C686B )
VIA AC97 codecs incorporated into VT8233, VT8233A, VT8233C, VT8235 and VT8237/R South Bridges ( VT8237 VT8235 VT8233/VT8233A/VT8233B/VT8235/VT8237 VT1612A VT8233/A/C VT8235CE )
VIA Six-TRAC (VT1616 Codec) ( VT1616 )
VIA Vinyl Eight-TRAC (VT1617 Codec) ( VT1617 )
VIA AC97 codec incorporated into VT8231 South Bridge ( VT8231 )
VIA VT1612A audio codec ( VT1612A )
VIA AC97 codec incorporated into VT8251 South Bridge ( VT8251 )
http://www.majorgeeks.com/VIA_AC97_V...ver_d4505.html
Staro 17.09.2005., 01:03   #2
sick_boy
sick_boy's Avatar
Postovi: 680
Može savjet: jeli bolje koristiti ovaj Via Vinyl driver ili original Realtek-ov (ALC850 na K8T800pro ploči)?
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 17.09.2005., 14:54   #3
Jelc
Super Moderators
Postovi: 17,485
Ne kužim???:confused:
Ako imaš Realtek zvučnu onda koristiš njihove drivere, ne VIA.
Staro 17.09.2005., 15:37   #4
sick_boy
sick_boy's Avatar
Postovi: 680
Ali rade mi i VIA Vinyl driveri i Realtekovi (hoću reći da zvučna radi i s jednim i drugim), pa se pitam koji su bolji (nemam tako dobro uho da primjetim neku veliku razliku).
ATI RX550 4GB
Arch Linux/Win 10
AMD Ryzen 7 6800HS
1TB Micron nVme HDD
Windows 11
Fujitsu Esprimo:
4GB DDR2 RAM
Staro 17.09.2005., 15:50   #5
Jelc
Super Moderators
Postovi: 17,485
Pa Realtekovi daju ipak bolji zvuk.
Tak je slično i kod mene-koristim Nvidia soft jer je fleksibilniji, Realtek daju bolji zvuk ali je interface ružan do bola
U stvari-budući da imam non-stop prikopčan i IN i OUT za video/audio, slušalice za Skype, i još hrpu toga Nvidiin soft mi je puno fleksibilniji za korištenje.
Za napraviti backup svog najnovijeg CD-a koristim ipak Terratec zvučnu koju spojim na linijski CD player
Nisu to nikakve high-end onboard zvučne da bi sad picanili...
