Staro 30.07.2013., 13:17   #1
golfw12
golfw12's Avatar
Postovi: 424
(riješeno) Biostar z87x 3d hi-fi restart button žmiga kao hdd lampica
kupio sam jučer navedenu ploču i imam jedan problemčić,
naime ploča ima power i restart dugmiće na ploči koji služe svrsi ALI (po mojoj predpostavci) taj dugmić umjesto da svijetli cjelo vrijeme (power dugmić svijetli crveno non stop) on mi funkcionira kao hdd activity lampica tj žmiga mi isto kao i lampica na kučištu za hard
nisam siguran da bi to prošlo kroz reklamaciju- ako se to uopče isplati reklamirat
al čisto informativno
konfa i5 4670k ->nije klokan, hyper 412s, biostar z87x3d hifi,8gb kingston predator 2400mhz,1tb wd,500gb hitachi,tx650,
CPU: AMD Ryzen 5 PRO 4650G@3.7GHz@ CM Hyper 212X
MBO: Gigabyte B450 AORUS PRO
RAM: 2 x 8 GB DDR4 3200Mhz CL16 Kingston HyperX Predator RGB
GPU: Radeon Onboard Graphics
SSD: Samsung 1Tb, NVMe
HDD: Seagate 1TB, Sata III
PSU: Corsair RM650X 650W
CASE: Phanteks ECLIPSE P400
MONITOR: AOC 24G2U @ 144HZ
MOUSE: Logitech MX518 Batman Edition
KEYBOARD: Logitech K200
PERIPHERY: RAZER Goliathus Control Alpha
OS: Windows 10 Home x64
PRINTER: HP LaserJet Pro M12w
CONNECT: T-Com VDSL 30/6 Mb Flat
CPU: Intel® Core™ i5-8250U@1.6GHz
RAM: 2 x 8 GB DDR4 2400Mhz
GPU: Intel® UHD Graphics 620
HDD: 256 GB M.2 SSD
PSU: HP 90W
LCD: 1.920 x 1.080 FHD-Display SVA
golfw12 je offline   Reply With Quote
Staro 30.07.2013., 14:58   #2
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
google :
Next, we have a Reset button and Power button, both with LEDs (the Reset LED functions as a HDD activity LED), a JLN2, JCOMS1 and J1 jumper, along with the diagnostic LED 2-digit display. The display also shows the CPU temperature after the system has booted up
http://www.madshrimps.be/articles/ar...board-Review/5
Staro 30.07.2013., 20:54   #3
golfw12
golfw12's Avatar
Postovi: 424
omg,
jesam mulac, tu sam i ja pročitao review ali sam izgleda preskočio taj dio,
a več sam paničario da sam negdje napravio kratki spoj ili ko zna šta
dobro sad imam jedno drugo pitanjce, jbg noob sam šta češ
dosad sam imao asrock ploče i uvijek je bilo pod njihovim realtek hd sound managerom je bilo opcije "speaker fill" no sad ovdje je nema, to sam koristio uvijek jer imam 5.1 zvučnike a ta opcija šalje zvuk na sve zvučnike,no sad na ovoj ploči nisam skužio kak to natjerat
HDD: 256 GB M.2 SSD
PSU: HP 90W
Staro 30.07.2013., 23:40   #4
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
A zasto bi to koristio kad mozes birat stereo quadrophonic, 5.1,7.1 ? stavi 5.1 i mirna bosna
Staro 31.07.2013., 11:47   #5
golfw12
golfw12's Avatar
Postovi: 424
krivo sam se izrazio, kao i obično
imam 5.1 zvučnike, podešeno mi je 5.1 u realtek softveru, sve ok
ali pošto večinu toga što slušam je u stereo, 2.0 2.1 ili kako god se zvao takav format, i onda mi nesviraju svi zvučnici samo ljevi, desni i woofer, i tu dolazi do izražaja speaker fill
jer šalje zvuk na sve zvučnike nebitno kakva je pjesma
HDD: 256 GB M.2 SSD
PSU: HP 90W
