Lokacija: Sisak
Postovi: 358
(riješeno) Bad sektori na novom hardu
Seagate baracuda 500 gb star 2 mjeseca već zeza, našao sam i s HD regeneratorom popravio 32 bad sektora na tri lokacije, ne znam jel taj hard već sada za reklamaciju, evo smart test nakon popravka. Serial: W2AMR3KR LBA: 976773168 Report By: HDDScan for Windows version 3.3 Report Date: 16.6.2013. 16:54:20 Num Attribute Name Value Worst Raw(hex) Threshold 001Raw Read Error Rate 1090940000000140-8D10006 003Spin Up Time 1001000000000000-0000000 004Start/Stop Count 0990990000000000-0510020 005Reallocation Sector Count 1001000000000000-0000036 007Seek Error Rate 075060000000023E-7321030 009Power-On Hours Count 1001000000000000-0319000 010Spin Retry Count 1001000000000000-0000097 012Device Power Cycle Count 1001000000000000-00A2020 183SATA Downshift Error Count1001000000000000-0000000 184End To End Error Count 1001000000000000-0000099 187Reported Uncorrectable Error 0600600000000000-0028000 188Reported Command Timeouts 1000990000000000-0004000 189High Fly Writes 1001000000000000-0000000 190Airflow Temperature 06606534 C 045 190Airflow Temperature Minimum06606533 C045 190Airflow Temperature Maximum06606534 C045 194HDA Temperature 03404034 C 000 194HDA Temperature Minimum03404017 C000 194HDA Temperature Maximum03404060 C000 195Error Rate0540390000000140-8D10000 197Current Pending Errors Count 1001000000000000-0000000 198Uncorrectable Errors Count 1001000000000000-0000000 199UltraDMA CRC Errors 2002000000000000-0000000 240Heads Flying Hours 100253174C690000-02F8000 241Total Host Writes 100253000000831F-5B69000 242Total Host Reads 100253000000B84B-2375000 |
Lokacija: Dalmacija
Postovi: 5,907
Ma nema tu price sta prije odneses to bolje |
Lokacija: Sisak
Postovi: 358
A jel će proći reklamacija obzirom na scan gore? |
Lokacija: Dalmacija
Postovi: 5,907
E to sam uredio al nije spremilo, na mobu sam, ja ove hex podatke ja neznam citat, ali ako se nevaram, taj repair samo oznaci sektore kao neiskoristive, nadalje ako mozes napravi low level format pa onda ponovo skeniraj |
Lokacija: Sisak
Postovi: 358
Low level cijelog diska neću raditi, imam na D i E particiji dosta prebačenih slika pa ću probat napravit wipe particije C i poslije format pa da vidimo, imam još 22 mjeseca garanciju pa stignem to riješiti. |
Lokacija: Petrinja
Postovi: 1,604
Problem ti je što bad sektori ne biraju particiju, ako ti se zadrže na logičkoj c imaš sreće. Moj savjet ti je da si napraviš full backup diska i odskeniraš sa hirenom disk tj. sa wd.ovim alatom te po potrebi naraviš low level. |
#8 | |
Lokacija: Sisak
Postovi: 358
![]() Zadnje izmijenjeno od: Gustavo. 16.06.2013. u 23:47. |
Lokacija: Sisak
Postovi: 358
Ovo je stanje nakon wipe i format C, čini se nema nekih promjena? ST500DM002-1BD142-W2AMR3KR-SMART.mht HDDScan S.M.A.R.T. Report Model: ST500DM002-1BD142 Firmware: KC45 Serial: W2AMR3KR LBA: 976773168 Report By: HDDScan for Windows version 3.3 Report Date: 19.6.2013. 19:06:56 Num Attribute Name Value Worst Raw(hex) Threshold 001Raw Read Error Rate 10709400000000DB-C168006 003Spin Up Time 1001000000000000-0000000 004Start/Stop Count 0990990000000000-05F1020 005Reallocation Sector Count 1001000000000000-0000036 007Seek Error Rate 0750600000000269-4567030 009Power-On Hours Count 1001000000000000-034C000 010Spin Retry Count 1001000000000000-0000097 012Device Power Cycle Count 1001000000000000-00AA020 183SATA Downshift Error Count1001000000000000-0000000 184End To End Error Count 1001000000000000-0000099 187Reported Uncorrectable Error 0560560000000000-002C000 188Reported Command Timeouts 1000990000000000-0004000 189High Fly Writes 1001000000000000-0000000 190Airflow Temperature 06406236 C 045 190Airflow Temperature Minimum06406234 C045 190Airflow Temperature Maximum06406236 C045 194HDA Temperature 03604036 C 000 194HDA Temperature Minimum03604017 C000 194HDA Temperature Maximum03604060 C000 195Error Rate05403500000000DB-C168000 197Current Pending Errors Count 1001000000000000-0000000 198Uncorrectable Errors Count 1001000000000000-0000000 199UltraDMA CRC Errors 2002000000000000-0000000 240Heads Flying Hours 1002533648DE0000-0324000 241Total Host Writes 1002530000009AAF-C15F000 242Total Host Reads 1002530000004F54-9328000 |
Datum registracije: Jun 2012
Postovi: 820
Ne znam samo čemu ti kopi/pejstovi nekih ljevih alata iz kojih se ništa ne vidi. Na hirens cd-u nađi segateovu dijagnostiku i testiraj, ako ne prođe testove znači da ne valja i nosiš na reklamaciju. |
Lokacija: Sisak
Postovi: 358
Zadnje izmijenjeno od: nino. 27.08.2013. u 02:41. |
