Staro 29.04.2013., 00:47   #1
Xenomorph
Arroyo settler
Xenomorph's Avatar
Lokacija: .::Zagreb::.
Postovi: 316
Ati Catalyst 13.5 Beta
AMD Catalyst 13.5 Beta for Windows
NOTE!
You must un-install AMD Catalyst 13.4 (if you have already installed AMD Catalyst 13.4) before installing AMD Catalyst 13.5 Beta
Feature Highlights of the AMD Catalyst™ 13.5 Beta Driver for Windows®
  • Performance gains seen on the entire AMD Radeon™ HD 7000 Series for the following:
    • Far Cry 3: Improves performance up to 4% with Anti-Aliasing enabled
    • Shogun II: Improves performance up to 20% with 8x Anti-Aliasing enabled
    • Tomb Raider: Improves performance up to 6%
    • Bioshock: Improves performance up to 6%
    • Borderlands 2: Improves performance up to 17%
  • Corruption is no longer seen on the AMD Radeon HD 7790 when TressFX is enabled in Tomb Raider
Xenomorph je offline   Reply With Quote
Staro 29.04.2013., 11:09   #2
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,073
Sa ovim driverima dobivam BSOD svaki put kad upalim dediciranu grafu na laptopu.
Imao sam 13.2 drivere, izbrisao ih, očistio sa Driver Fusionom i instalirao ove.
Idem probati 13.4.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Mario92 je online   Reply With Quote
Staro 29.04.2013., 14:38   #3
alen.s
alen.s's Avatar
Postovi: 1,441
iman vtx7770 i ovaj i prošli driver mi bacaju "plavi"..............zaobič u širem luku !
edit: vratio na 13.1 i sad je sve ok, ne samo to nego se čak i index vratio nazad na 7,7 sa 7,6 koliko san ima sa ovom betom i 13.4.......eto..
+ rješija mi se i ovaj prob sa Path of Exile; http://forum.pcekspert.com/showpost....&postcount=256
Zadnje izmijenjeno od: alen.s. 29.04.2013. u 16:31.
Staro 29.05.2013., 12:55   #4
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Evo već i 13.6 beta, da ne otvaram novu temu
http://support.amd.com/us/kbarticles...etaDriver.aspx
