Staro 25.03.2013., 11:04   #1
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,144
hotfix za win7
vako MS je izdao nedavno grupu patcheva (u 1) koji fixaju
sporost OS-a i mreze
no kakvi su degenerici nedaju direktan download nego korisnik
mora imati internet exploder da bi to skinuo
(ja ga nemam !)
pa ajde ako ima neka dobra dusa da mi to skine :/
http://support.microsoft.com/kb/2775511/en-us
Why would you invite a mushroom to a Christmas party? He's a fun guy to be with.
Why do mummies like Christmas so much? Because of all the wrapping.
Why does Santa have three gardens? So he can "ho ho ho".
HumWeed je offline   Reply With Quote
Staro 25.03.2013., 11:09   #2
nino
nino's Avatar
Postovi: 12,613
Kako sam na brzinu pogledao:
You can download and install these hotfixes directly from the following Microsoft Knowledge Base articles:•
2581608
Logon scripts take a long time to run in Windows Vista, in Windows Server 2008, in Windows 7 or in Windows Server 2008 R2
2752259
An update that improves the performance of the Printbrm.exe command-line tool in Windows 7 or in Windows Server 2008 R2 is available
Or, you can manually or programmatically set two registry keys by using the following steps:
•To enable update 2581608, configure a REG_DWORD Value named RunLogonScriptsNormally under the following path, and set the value to a decimal value of 1:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
•To enable update 2752259, configure a REG_DWORD Value named BrmDisableOpc under the following path, and set the value to a decimal value of 0:
HKEY_LOCAL_MACHINE \SYSTEM\CurrentControlSet\Control\Print
Staro 25.03.2013., 11:20   #3
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,144
nasao sam alternativne linkove, za nas kojiima je WU disejblan i IE maknut
x86: http://goo.gl/0V91x
x64: http://goo.gl/MXsmu
