Staro 29.11.2012., 00:56   #1
santos
santos's Avatar
Lokacija: Čakovec / AT
Postovi: 1,782
(riješeno) Acer Aspire One D280 - online multimedia zacukava
ne znam dal je problem hardverski ili softverski pa sam temu stavio ovdje.
acer aspire one D280, intel atom 1,6 ghz, apgrejdan na 2 gige rama (ddr2), 160 GB hard, licencirani windows xp.
dok gledam i slusam muziku s harda, radi ok.
dok slusam muziku na youtubeu ili recimo livestream antene zagreb, muzika zna zacukavat (kao da ima smetnje ) , te se muzika uspori, ko da umjesto brzine 1.0 x slusam na 0.7 x
hard je uredno defragmentiran, praznjenje cache memorije browsera ne pomaze, ccleaner pocistio sve sta se pocistiti dalo.
please help
santos je offline   Reply With Quote
Staro 29.11.2012., 01:03   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Pogledaj opterećenje procesora i popunjenost rama kada počinje zakuckavanja.
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 29.11.2012., 01:17   #3
santos
santos's Avatar
Postovi: 1,782
startao nes na youtubeu - krenulo ok, proc 85-95% , rami 1,2 gige
startao na fejsu browser igricu u flashu.
proc 100%, ako je otvoren tab s browser igricom, rami max 1,5 giga
ako je otvoren bilo koji drugi tab, proc oscilira izmedju 45% i 100%, muzika i dalje zacukava jos neko vrijeme nakon sto zatvorim tab s flash igrom (valjda dok se ne killa proces)...
dal je proc na izdahu s obzirom da mi se to pocelo tek nedavno dogajati, dosad nije nikad bilo problema s tim "multitaskingom"
Staro 29.11.2012., 01:28   #4
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
nedavno je izasao noviji flash, pa ga probaj updateati. bez onog mcfee-ja .
i da, flash inace ubija kompove koji su stariji, ili koji imaju slab cpu sa integriranom grafickom. stvarno mi je nevjerovatno da je usrani flash postao toliko zahjevan, smijurija jedna........
Staro 29.11.2012., 01:33   #5
santos
santos's Avatar
Postovi: 1,782
apdejtao, same crap :/
a bio sam tako zadovoljan svojim netbookom....
le crap...
zna neko dal se i novije verzije netbookova koje podrzavaju HD isto tak ponasaju ili?
ultrabookovi trenutno nisu u mom cjenovnom rangu
Zadnje izmijenjeno od: santos. 29.11.2012. u 01:42.
Staro 29.11.2012., 11:53   #6
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Procesor ti je 95 - 100%, burko ti je odgovorio flash killa sve. Isto imam konfu sa najjačim pentiumom M i kada se otvori njuškalo i sve ono poskakak gore sve šteka...
Netbook koji podržava HD ne znači da će bolje raditi u tvojoj situaciji . Traži nešto sa "normlanim" procesorom a ne atomom.
Ryzen 7 2700X
2x 8gb Crucial
B450 Aurus Elite
GTX 1060
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
Harman Kardon
MX revolution
Battery grip
Sony: 18-70, 55-200
Staro 29.11.2012., 14:03   #7
MMI
MMI's Avatar
Postovi: 913
probaj pokrenuti YT desni klik na sliku dok je u malom prozoru---settings pa makni kvačicu sa enable hardw. acc
MMI je offline   Reply With Quote
Staro 29.11.2012., 14:14   #8
RAUL
Lokacija: Worldwide
Postovi: 2,553
Autor santos Pregled postova
le crap...
Imam ultrabook sa slabijim procesorom od tvojeg i sve radi odlicno.Da ti mozda nije problem u brzini interneta?
Staro 29.11.2012., 14:26   #9
Burko
Burko's Avatar
Postovi: 2,317
kakve veze ima brzina interneta sa opterecenjem procesora?
Staro 29.11.2012., 15:12   #10
RAUL
Lokacija: Worldwide
Postovi: 2,553
Nikakve, ali ima sa livestreamom.
Staro 29.11.2012., 15:14   #11
santos
santos's Avatar
Postovi: 1,782
20 megabita, nije internet
cak nije ni problem sta je proc na 100% jer oscilira on tako gore dole i dok su druge stvari upaljene...
rami isto nisu, hard nema bad sectora.... ne znam vise kaj bi moglo bit....
Staro 29.11.2012., 15:32   #12
RAUL
Lokacija: Worldwide
Postovi: 2,553
Jesi probao iskljuciti hardversko ubrzanje na youtube?
Staro 29.11.2012., 15:36   #13
santos
santos's Avatar
Postovi: 1,782
ista stvar...
u biti ajde kao da je malo bolje, al i dalje se cuje zacukivanje ak nes radim u drugom prozoru...
Staro 29.11.2012., 15:52   #14
RAUL
Lokacija: Worldwide
Postovi: 2,553
A da probas podici neku live opciju linuxa?Pa ako je na njoj isti problem onda bi moglo biti nesto hardverski.
Staro 29.11.2012., 17:47   #15
santos
santos's Avatar
Postovi: 1,782
nemam gotovo nikakvih iskustava s linuxom (osim backtracka ) , tak da mi je to malo strano podrucje
Staro 06.04.2013., 19:02   #16
santos
santos's Avatar
Postovi: 1,782
problem je bio s cache memorijom... dok bi se napunila (ocito bilo postavljeno na 64 MB jer mi je tolko pokazivalo dok bi obrisao cache) , ostatak sistema je bio u totalnoj banani.... googlao kako povecat cache memoriju na xp-u:
system properties>advanced>performance settings>advanced>memory usage
"by default the computer is set to use greater share of memory to run your programs.
adjust best performance of:
bilo na programs, prebacio na system cache.
razlika - NEBO I ZEMLJA. (nema vise zacukavanja, sve radi puno bolje)
ja tu postavku nisam promjenio, jedino sta mi pada na pamet je da ju je neki windows update sam promjenio...
slow is smooth, smooth is fast...
Zadnje izmijenjeno od: santos. 06.04.2013. u 19:10.
Staro 10.04.2013., 23:50   #17
darkydark
N0teb00k n00b
darkydark's Avatar
Lokacija: Zagreb/Koprivnica
Postovi: 2,109
A ak oces jos malo vise performansi imat mozes instalirati ad-block ubije svu silu reklama koje su vecinom u flashu i sve glađe radi - barem meni na ovom c2d laptopu pomaže.
1TB A2000, 2TB KC3000
Linđa
Truenas Scale
Staro 11.04.2013., 00:18   #18
santos
santos's Avatar
Postovi: 1,782
instalirao sam al mi onda blokira loadanje nekih sajteva kompletno, trebao bi se poigrat u postavkama...
a opet mi recimo ne zblokira bas sve sta bi trebao... (npr flash reklamu iznad browser igrice na fejsu)
