Staro 08.11.2012., 12:54   #1
Braja
Braja's Avatar
Lokacija: Bjelovar
Postovi: 86
KVM Switch i kompatibilnost
naime priključio bih 2 kompa na 1 monitor, 1 miša i 1 tipkovnicu
pa sam razmišljao o kvm svitchu
najjeftiniji koji sam našao i da podržava DVI monitor i USB miša i tipkovnicu
je rolline-ov
Description
- Controls two computers from a single console (USB keyboard, DVI monitor, USB mouse)
- Switch with two attached KVM cables (each 1.2 m)
- Max. resolution (nominal): 1920×1080 @ 60Hz
- Connectors console side: 1× DVI, 2× USB, 2× 3.5mm audio plug
- Connectors computer side: 2× DVI, 2× USB, 4× 3.5mm audio plug
- Supports independent audio switching
- Easy switching by push buttons or hot keys; auto scan function
- Keyboard and mouse emulation
- LED display for PC status monitoring
- Hot-swapping and plug & play
- Bus powered
- Supports Windows 98SE/ME/2000/XP/2003 Server/Vista
Technical Data
- 19" compatible: No
- Dimensions (H×W×D): 30×85×70 mm
- Analogue Console: Mouse/Keyboard connection: USB
- Analogue Console: Monitor connection: 1× HD 15pol. BU
- Quantity of analogue consoles: 1
- Quantity of PCs: 2
- Print button on device: No
- Colour (Design profile): silver
- Hot plug compatible: No
- Integrated Hub: No
- Cascadable: No
- Integrated console: No
- Material (casing): plastic
- Max. resolution (nominal): 1920×1080 60Hz
- Monitor size of integrated console: not applicable
- Power supply unit required: No
- PC: connection on moulded cables: Yes
- PC: mouse/keyboard connection: 2× USB
- PC: monitor connection: 2× DVI
- Switching over Hot Keys: Keyboard
- Switching over OSD: No
- Switching over Scan Run: Yes
- Keyboard/mouse emulation: Yes
- Keyboard layout: not applicable
- Technical particularity: LED display for easy status monitoring
- Trackball/Touchpad integrated console: not applicable
- Supported PC-Systems: USB
i košta 450-500 kuna to je prihvatljivo
samo imam monitor od 23 incha
a u specifikacijama piše
"- 19" compatible: No"
e sad me zanima da li će to čudo raditi sa mojim dellom U2311H
hvala !
CPU: Intel QX9650 C1 4.0 GHz (24/7) (1.28v) (10x400) under TRUE (2 x Nanoxia 2000rpm)
MBO: ASUS Maximus II FORMULA
RAM: Corsair Dominator 2X2 GB with FAN (TWIN2X2048-8500C5DF)
VGA: XFX Radeon HD5770 1GB XXX Edition
HDD: Intel 2 x 40GB X-25 V (raid 0) + 3 x WD Black 1TB (1001FALS)
PSU: Corsair HX650 650w Modular
OS: Windows XP Pro SP3
Monitor: LCD 22" Samsung T220
Sound: Logitech G51 Surround Sound Speaker System
CPU: Intel E8400 E0
RAM: OCZ 4GB Reaper X HPC PC2-8000 (1000MHz)
VGA: Gainward 8800GTS Golden Sample 320
HDD: 2 x seagate 320 (raid 0)
PSU: Corsair HX620 620w Modular
OS: Win XP SP3
Monitor: LCD Samsung 940NW
CPU: Intel Pentium 4 3.4 Prescott W/ Sythe Mugen
MBO: ASUS P4C800-E Deluxe
RAM: Kingmax 4x512MB DDR500 Highcore
VGA: Sapphire X1950pro 512MB 256bita
HDD: Western Digital 40GB ATA
PSU: Fortron 350W PNF Series
OS: Win XP SP3
CPU: Intel Pentium 4 3.0 Northwood
MBO: ASUS P4P800-E Deluxe
RAM: Kingmax 4x512MB DDR400
VGA: ASUS 9600XT 128MB
HDD: Western Digital 80GB ATA
PSU: Codegen 400W
OS: Win XP SP3
Monitor: Samsung SyncMaster 755DFX
CPU: AMD Athlon 2500+
MBO: ABIT NF7-S v2.0
RAM: A-DATA 2x512MB DDR400
VGA: Sapphire 9600XT 128MB
PSU: PSU 400W šrotex
OS: Win XP SP3
CPU: AMD Athlon 2500-M w zalman 7000AlCu
RAM: Kingmax Gold 2x512MB DDR466
VGA: Leadtek 7600GT 256MB
PSU: Chieftex 400W
OS: Win XP SP3
CPU: Intel Tualatin 1.4-S
MBO: ASUS TUSL2-C
RAM: Hynix 2 x 256 MB SDRAM PC133
VGA: Sapphire 9550 128MB
PSU: PSU 350W šrotex
OS: Win XP SP3
Braja je offline   Reply With Quote
Staro 08.11.2012., 13:02   #2
zdravko_c
Lokacija: Vinkovci
Postovi: 531
mislim da ti se - 19" compatible: No odnosi na mogućnost ugradnje u komunikacijske ili mrežne ormare gdje je širina racka 19", nek me netko ispravi ako griješim
zdravko_c je offline   Reply With Quote
Staro 08.11.2012., 13:09   #3
Postovi: 23,593
Da, 19" je sinonim za 19" rack tj ormar. U ovoj priči nebitno.
Staro 08.11.2012., 13:14   #4
windfucker
Iz iskustva: dobro obrati pozornost na hotkey-eve tj kombinacije tipki za prebacivanje sa kompa na komp, jer neki nisu kompatibilni sa određenim proizvođačima tipkovnica, a ulogu igra i USB/PS2 konektor (začudno, Logitech na jednome dijelu njih nije podržan), konkretno ja imao problema sa Aten-om u toj kombinaciji, dok je nekakva Genius-ova vulgaris tipkovnica šljakala najnormalnije...
Staro 08.11.2012., 19:12   #5
Braja
Braja's Avatar
Lokacija: Bjelovar
Postovi: 86
hvala vam na objašnjenju
izgleda da ću riskirati 450 kuna pa ćemo vidjeti
CPU: Intel E8400 E0
OS: Win XP SP3
OS: Win XP SP3
PSU: Codegen 400W
OS: Win XP SP3
OS: Win XP SP3
PSU: Chieftex 400W
OS: Win XP SP3
MBO: ASUS TUSL2-C
OS: Win XP SP3
