09.07.2012., 01:38 | #1 |
Lokacija: Restricted Area
Postovi: 337
Javascript - koristenje slike umjesto gumbica
Tenutno ovako izgleda i sve radi... head Code:
function calc1(form) { a = form.a.value*form.b.value; c=form.c.value*form.b.value; u=a-c; form.total3.value = u; } Code:
<form name="form1"> <table border=0 cellpadding=4 cellspacing=1> <tr> <td width="310" height="219" align=center><p> <input type="text" name="a" size=5> </p> <p> <input type="text" name="b" size=5> </p> <p> <input type="text" name="c" size=5> </p> <p> <input type="button" value="Izračunaj" onclick="calc1(this.form)" /> </p> <p> <input type="text" name="total3" size=5 maxlength=40 /> kn</p></td> </tr> </table> </form> Code:
<input type="image" src="button.gif" onclick="javascript:calc1(this.form)" /> |
09.07.2012., 10:56 | #2 |
Bazinga
Postovi: 224
Probaj ovako. head: Code:
<script type="text/javascript"> function calc1(form) { a = form.a.value*form.b.value; c=form.c.value*form.b.value; u=a-c; form.total3.value = u; } </script> <style type="text/css"> button {padding:0;} </style> Code:
<form name="form1"> <table border=0 cellpadding=4 cellspacing=1> <tr> <td width="310" height="219" align=center><p> <input type="text" name="a" size=5> </p> <p> <input type="text" name="b" size=5> </p> <p> <input type="text" name="c" size=5> </p> <p><button type="button" onclick="javascript:calc1(this.form)"> <img src="button.gif"> </button> </div> </p> <p> <input type="text" name="total3" size=5 maxlength=40 /> kn</p></td> </tr> </table> Zadnje izmijenjeno od: mbozick1. 09.07.2012. u 11:03. |
09.07.2012., 14:54 | #3 |
Postovi: 337
Hvala, radi... Samo... slika gumbica je nesto manja od "pravog" pa se vidi u pozadini, posto sam kod prepravio u notepadu neznam da li se moze "pravom" gumbu smanjit dimanzija Pozabavit cu se s time kad budem za kompom. Imas pivu kad dodes u Zagreb |
09.07.2012., 14:57 | #4 | |
Bazinga
Postovi: 224
Evo, ja sam probao tocno kako sam ti napisao i meni se vidi samo button.gif (ne vidi se orginalni gumb iza) Ok, na pivu racunam |
16.07.2012., 18:56 | #7 |
Postovi: 337
Trebao bih jos jedan dodatak programu. Problem nastaje kada se za decimalni zarez koristi, zarez (npr. 1,2) u rezultatu ispise NaN Kada je decimalni zarez, tocka sve super radi. Posto neznam bas programirat, trebala bi mi linija koda koja ce zarez, zamjenit tockom |
16.07.2012., 20:15 | #8 |
Datum registracije: Dec 2010
Postovi: 90
Pa napravi samo da ti pregleda value iz forme i replace "," s "." i to je to ovako nekako function calc1(form) { a = form.a.value.replace(",",".")*form.b.value.replace(",","."); c=form.c.value.replace(",",".")*form.b.value.replace(",","."); u=a-c; form.total3.value = u; } ovo mi prvo pada na pamet.... |
16.07.2012., 20:32 | #9 |
Postovi: 337
Radi, hvala |
