Staro 30.03.2012., 08:50   #1
greenfly
Od nonine sestre kunjado
greenfly's Avatar
Lokacija: (Vinjro)
Postovi: 1,130
Wireless neće od jutros :)
pozdrav...
Wireless mi neće.. Konfiguracija je iz mog kompa , a OS je W7 x64
Spajam se preko D-linkovog DWL-G122 ver 3 sticka, ili TPLINK-a TL-WN422G-a ..
Jutros mi je crveni IKSIĆ na konekciji u notification arei..
Probao restart , i kompa i veze,ali neće. Kad idem na troublešut problem baca mi ovo :
Kad pokušam startat servis "wlan autoconfig" baca mi ovo:
Eto,, pa bi dobrodošao savjet...
greenfly je offline   Reply With Quote
Staro 30.03.2012., 09:15   #2
Brzi Picek
Brzi Picek's Avatar
Datum registracije: Nov 2011
Lokacija: Ri,De,Čk,Zg itd
Postovi: 500
Pa probaj upaliti servis !
Ako onda nakon restarta neće , e onda imaš pojavu zvana "upomoć" ako itko zna zašto neće startati !
Vidi malo Startup kaj ti sve diže onda .
to su one igre kada se pogubi tko je gazda u PC-u
Brzi Picek je offline   Reply With Quote
Staro 30.03.2012., 09:16   #3
greenfly
greenfly's Avatar
Lokacija: (Vinjro)
Postovi: 1,130
Ma sve sam to već probao...
Eto ovo je upalilo:
Step 1: Click START button
Step 2: In the Search area, type "regedt32" (of course don't include the ""), right click on the search result and "Run as Administrator".
Step 3: Click on "HKEY_LOCAL_MACHINE", should expand out to a list of stuff
Step 4: Next choose "SYSTEM", should expand again
Step 5: Choose "CurrentControlSet", expands again
Step 6: Choose "Services", expands to a super large list of stuff
Step 7: Click on "Dhcp", the right window will show the files in that folder
Step 8: Double click on "DependOnService"
Step 9: Delete all the words in text area, except "Afd", and click OK. You are done here
Step 10: Next under "Services", look for "EapHost", this should be a few folders below Dhcp Step 11: Same thing, double click on the file "DependOnService"
Step 12: Delete everything in the text are and click OK. You are done.
Može lock
