Staro 18.11.2011., 09:42   #1
Minelis
Datum registracije: Nov 2011
Postovi: 2
Kako podesiti Spy - da primam podatke na mail?
Pozdrav svima!
Dakle, zanima me kako da podesim Spy 007 da mi salje podatke na mail?
Probao sam ali ocito nesto krivo radim.
Evo tu su upute - http://www.e-spy-software.com/007manual/ pa klik na Advanced Settings
zahvaljujem
Minelis je offline   Reply With Quote
Staro 23.11.2011., 13:14   #2
Minelis
Postovi: 2
Evo tu su upute. Moze li mi tko pomoci, molim Vas, da to podesim?
If you want to receive the logs at a remote computer, you can input your email address here, such as "tom@hotmail.com". If you do not understand what is the "SMTP server", just leave it as the default value "mail.e-spy-software.com". If this setting does not work for you, you can input your own SMTP server here, for example, "mail.aol.com", etc. Since most of nowadays SMTP servers require a user authentication, you should input the appropriate value in "Username" and "Password" textbox. After filling these filed you can press the "Test Now" button to check if your settings work for you.
From version 3.90 it will deliver logs to our remote online server instead of sending the log to your email box, then you can remotely view logs with your browser through the Internet from anywhere!
Since the screen snapshot pictures may be too large to delivered by email, we offer the FTP delivery options. The IP address or Domain name of the FTP server as well as the appropriate Username and Password are required to send logs via FTP. The remote directory is optional. Leaving it blank to allow to store logs at server's current directory.
You also have the choice to decide what logs will be delivered. Simple opt-in or cancel the 5 log file options.
If you opt-in the "Clear all logs after delivery", 007 Spy will completely delete all the local log files after a successful Email/FTP delivery. So be careful to opt in this check box.
Staro 23.11.2011., 13:40   #3
rog
Postovi: 68
Autor Minelis Pregled postova
Ili gledaj logove na njihovoj stranici ili nabavi verziju ispod 3.90.
rog je offline   Reply With Quote
