Staro 11.11.2011., 11:05   #1
Makaveli2
Makaveli2's Avatar
Postovi: 100
Usb stick pretvoren u disketu
Ovako s ovakvim nečim se još nisam susreo, frend mi je dao USB stick i reko mi da mu ga je netko pretvorio u disketu da to probam rješit. Prvo mu nisam vjerovao ali meni računalo njega stvarno učitava kao disketu. I u "device menageru" isto tako. Pokušao sam ga ponovo formatirat, sve što mi je palo napamet on uporno ostaje disketa.
Ima li možda netko neku ideju?
Unaprjed zahvaljujem.
Makaveli2 je offline   Reply With Quote
Staro 11.11.2011., 13:57   #2
Postovi: 17,127
Insert your flash drive and let Windows mount it.
Open Control Panel
Select Administrative Tools
Select Computer Management
Under Storage, select Disk Management
Your flash drive will show up there, with the drive letter Windows assigned it.
Right-click it. Select Change Drive Letter and Paths...
In the dialog that pops up, select Change...
From the drop-down list that appears in the subsequent pop-up, pick the drive letter you want.
Note that if you already have A: assigned to a drive, you'll need to change its default drive letter first.
Once you have completed this operation, The local installation of Windows will always assign that letter to the drive you've assigned it to, any time you insert it. However, the assignment is only good for one computer. To use the same flash device as drive A: on another computer, you'll need to repeat the procedure.
Neznam koliko će ti pomoći ali ima dosta toga na google...
