Staro 16.09.2011., 16:24   #1
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
Smile Corsair Vengeance M60 Performance FPS & M90 Performance MMO Laser Gaming Mouse
novi proizvodi iz Corsaira:
Vengeance™ M60 Performance FPS Laser Gaming Mouse
Technical Specifications
5700 DPI — Avago ADNS-9500 LaserStream Gaming Sensor
Adjustable DPI in 100 DPI increments
1000Hz/500Hz/250Hz/125Hz (1ms/2ms/4ms/8ms) selectable response time
Tracking up to 165 inches per second, up to 30g acceleration, and automatic frame rate control
Adjustable lift distance — five selectable levels to fit your play style
Surface quality detection
8 individually programmable buttons
Side mounted sniper button provides user settable DPI change while pressed for enhanced precision targeting
Comfortable ergonomic design with soft-touch surfaces and grip improving textures
Omron left and right click switches rated for eight million operations
Aluminum metal frame and base for improved rigidity and mass distribution
Solid metal, weighted scroll wheel with rubberized scroll surface for improved finger traction control and feel
Ultra Low Friction PTFE pads for smooth performance and accurate gliding
USB Connector with gold plated contacts
1.8m lightweight non-tangle cable
ocekivana cijena: $69
Vengeance™ M90 Performance MMO and RTS Laser Gaming Mouse
5700 DPI Avago ADNS-9500 LaserStream Gaming Sensor
1000Hz/500Hz/250Hz/125Hz — 1msec/2msec/4msec/8msec response time — user selectable
Tracking rate of up to 165 inches per second, up to 30g acceleration, automatic frame rate control
Five selectable levels to fit your play style
15 programmable buttons
Nine ergonomically placed, side-mounted programmable buttons
48KB of on-board memory for storing up to six "on the go" profiles with active profile LED
ocekivana cijena: $79
Zadnje izmijenjeno od: DeadMan+. 16.09.2011. u 16:42.
DeadMan+ je offline   Reply With Quote
Staro 03.11.2011., 13:20   #2
izi
izi's Avatar
Lokacija: Vinkovci - Slavonski Brod
Postovi: 139
Ovaj corsair samo jos aute treba pocet proizvodit
izi je offline   Reply With Quote
