Staro 09.03.2011., 13:52   #1
chumaman
chumaman's Avatar
Lokacija: na brdu daleko
Postovi: 99
AMD Catalyst™ 11.4 early preview – “Mjölnir”
Eto novog preview-a s preskokom 11.3
http://support.amd.com/us/kbarticles...lypreview.aspx
AMD Catalyst™ Driver 11.4 early Preview Features:
· Delivers performance enhancements for the AMD Radeon™ HD 6000 Series & Windows 7.
· Includes enhancements to the AMD Catalyst Control Center™
o New task based Display Management controls
§ Simplifies the configuration of displays and display settings
o New Eyefinity setup group
§ Setting up an Eyefinity group has never been easier
o New branding (based on system configuration)
§ AMD based platform – AMD VISION Engine Control Center
§ Discrete AMD GPU with Intel CPU – AMD Catalyst Control Center™
o AMD Catalyst update notification (found within the Information Center)
§ Please note this functionality is not yet enabled, but will be in a future AMD Catalyst release
§ This feature will be used to notify users that new AMD Catalyst software packages are available
· Fixed cases where Dragon Age 2 would hang in DirectX11 on ATI Radeon™ HD 5800 Series products.
Zadnje izmijenjeno od: chumaman. 09.03.2011. u 13:53. Razlog: ispravak
chumaman je offline   Reply With Quote
Staro 09.03.2011., 15:03   #2
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Neznam jel to do mojeg kompa al ovo se fakat sporo instalira. Vec pol sata se nije mrdnulo od odokativnih 15%..
edit: 50% i jos se instalira.. :/
Cancel and delete .
Zadnje izmijenjeno od: viper. 09.03.2011. u 15:42.
viper je offline   Reply With Quote
Staro 09.03.2011., 15:29   #3
chumaman
chumaman's Avatar
Postovi: 99
Pa izgleda da je do tvog kompa jer instalacija traje ko obično.
Staro 09.03.2011., 23:44   #4
2 die 4
2 die 4's Avatar
Postovi: 2,276
Za sada sve radi normalno!
BTW koristim Firefox 4.0b12 i dobro radi, ovo govorim jer je bilo prije problema sa tim browserom i grafikom!
RedGreenBlue
Staro 09.03.2011., 23:46   #5
Minox
Minox's Avatar
Postovi: 565
jeli ih je neko isprobao , kakva poboljsanja donose u 6000 seriji
Minox je offline   Reply With Quote
Staro 12.03.2011., 17:12   #6
Antiša
Datum registracije: Dec 2010
Postovi: 147
Ja sam probao na 4870. Rade odlično, 11.2 su imali preveliko curenje memorije nakon nekog vremena i restart bi bio neophodan.
Antiša je offline   Reply With Quote
Staro 13.03.2011., 10:55   #7
elina08
Seven
elina08's Avatar
Datum registracije: Jul 2009
Postovi: 97
Ako netko želi popraviti HWBot Unigine Heaven rezultat ovaj driver se meni pokazao kao vrlo dobar
CCC 11.2
X1519
HD6950@976/1375MHz
CCC 11.4 Preview
X1644
HD6950@975/1377MHz
Zadnje izmijenjeno od: elina08. 21.03.2011. u 19:08. Razlog: ispravak
elina08 je offline   Reply With Quote
Staro 13.03.2011., 13:31   #8
AlphaDog
AlphaDog's Avatar
Lokacija: Ri
Postovi: 37
AlphaDog je offline   Reply With Quote
Staro 17.03.2011., 16:49   #9
krlja
krlja's Avatar
Lokacija: Ne znam
Postovi: 65
koji su najbolji driveri za 4870 radeon?mislim od 10.3 do 11.4?
krlja je offline   Reply With Quote
Staro 22.03.2011., 16:35   #10
Starsailor
Starsailor's Avatar
Datum registracije: Jan 2011
Lokacija: CRO
Postovi: 219
Ovi driveri su popravili podosta bugova, pogotovo što se tekstura u igrama tiče.
Starsailor je offline   Reply With Quote
Staro 22.03.2011., 21:10   #11
xtreme96
OC addict
xtreme96's Avatar
Datum registracije: Apr 2009
Lokacija: Gothenburg, Sweden
Postovi: 1,001
Jel ima nekakvog pomaka za HD4800 seriju?
Ja imam HD4850 i sada sam na 9.8,probao sam i 10.3 ali dalje nisam htjeo probavat jer sam vidio da ljudi imaju dosta problema,kakvi su ovi driveri?
Pošten trgovac: 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15...
- prije mi je bio nick "xTreme Gamer" (profil je isti ali sam promjenio nick)
xtreme96 je offline   Reply With Quote
Staro 23.03.2011., 12:02   #12
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Mislim da za starije serije poboljšanja nema. Ako i ima sigurno je neprimjetan.
sinisa1989 je online   Reply With Quote
Staro 23.03.2011., 15:52   #13
bAKa-47
Postovi: 157
Autor xTreme GaMeR Pregled postova
za tu graficku ni nemoj ici dalje od 10.3
bAKa-47 je offline   Reply With Quote
Staro 23.03.2011., 16:43   #14
Baja 001
Baja 001's Avatar
Postovi: 7,504
Ikakav boost overall za HD6870?
Staro 24.03.2011., 09:49   #15
saber_tooth
Old School
saber_tooth's Avatar
Lokacija: SB <-> MÜC
Postovi: 392
Autor Antiša Pregled postova
Hej, kako ti rade ovi driveri u igrama i općenito u windowsima?
Da upgradeam na njih sa starih 10.2?
Imao sam problema sa svim novima, pa nisam previse optimistican.
saber_tooth je offline   Reply With Quote
Staro 29.03.2011., 13:47   #16
Sharkaat
Vjeverica
Sharkaat's Avatar
Lokacija: Stockholm
Postovi: 100
5850 report: u HWBot Unigine Heaven cca 720 na 750, za sada zadovoljan, flash filmici jos nisu srusili driver <3.
Sharkaat je offline   Reply With Quote
Staro 30.03.2011., 11:14   #17
HD3850
HD3850's Avatar
Postovi: 323
hmm..cek ova verzija drajvera je izasla vec prije, a sad tek izisli 11.3.. ne kuzim uopce kakva je razlika sad? i da li mi se isplati stavljati 10.3??
HD3850 je offline   Reply With Quote
Staro 30.03.2011., 12:55   #18
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Autor HD3850 Pregled postova
Izašla je prije, ali kao "beta", "nepodržana", "tehno preview" ili kako ćeš je već nazvati. Znači nije službena, nije testirana, i nije konačna i stavljaš je na vlastitu odgovornost
Staro 30.03.2011., 16:02   #19
HD3850
HD3850's Avatar
Postovi: 323
ok..nista od toga..ako su ovi 11.3 ok...njih cu staviti
Staro 03.04.2011., 16:37   #20
chumaman
chumaman's Avatar
Postovi: 99
LOLčina malo žešće,ne vidim ni tragu problemu,nije podržana
Staro 03.04.2011., 19:53   #21
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Autor chumaman Pregled postova
Drago nam je, i mislim da govorim u ime sviju kad kažem da smo sretni što si to podijelio s nama
