Staro 22.02.2011., 11:27   #1
Lika091
Lika091's Avatar
Lokacija: Zagreb - Brinje
Postovi: 844
Sakrio sam disk, pomozite
Idem na net preko Vip sticka pa kada god bi ga piknuo u komp iskakao bi F: disk(ono VMC Lite 9.3.3.1) i onda je pametan negdje sam naletio i sakrio da mi neiskače svaki put kada ga uključim na komp. Znači nije više vidljiv tamo pokraj C,D, DWD rw pogona....
Kako da to vratim nemogu nikako više naići.
E da kada izvadim Vip stick i idem ubacit običan USB stick on isto bude nevidljiv jer se smjesti na F: mjesto.
Radi se o Win 7 hrvatski.
Staro 22.02.2011., 11:47   #2
Karlo2304
Karlo2304's Avatar
Datum registracije: Mar 2008
Postovi: 77
Here's How:
  1. Click on the Start button and then choose Control Panel.
  2. Click on the System and Security link.
    Note: If you're viewing the Large icons or Small icons view of Control Panel, you won't see this link so just click on the Administrative Tools icon and skip to Step 4.
  3. In the System and Security window, click on the Administrative Tools heading located near the bottom of the window.
  4. In the Administrative Tools window, double-click on the Computer Management icon.
  5. When Computer Management opens, click on Disk Management on the left side of the window, located under Storage.
    After a brief loading period, Disk Management should now appear on the right side of the Computer Management window.
    Note: If you don't see Disk Management listed, you may need to click on the |> icon to the left of the Storage icon.
  6. You can now partition a hard drive, format a hard drive, change a drive's letter, or do whatever else you need to do in Windows 7's Disk Management tool.
U Disk managmentu staviš neko slovo koje je slobodno (za stick)i to ti je to...
Karlo2304 je offline   Reply With Quote
Staro 22.02.2011., 13:59   #3
Lika091
Lika091's Avatar
Postovi: 844
Ovaj postupak je OK, ali to nije to jer svaki put moram raditi isti postupak kada ubacujem bilo kakav Stick u komp a izvađen je Vip stick
Nekako sam sakrio slovo F: .....
Staro 22.02.2011., 14:08   #4
Postovi: 23,596
Prekopaj postavke prikazivanja u sys tray - u, ono ima cijela lista šta ćeš upalit / ugasit da ti prikazuje. Mislim da je tu rješenje. Provjeri i AutoRun.
Staro 22.02.2011., 17:05   #5
Lika091
Lika091's Avatar
Postovi: 844
nema nigdje, još se traži pomoć
Staro 22.02.2011., 18:52   #6
Damanalovca
Lokacija: Kraj Bosuta
Postovi: 19
jesi li probao točku vraćanja, to bi trebalo jednostavno riješiti
Čemu žurba ako je cilj smrt?!
Damanalovca je offline   Reply With Quote
Staro 22.02.2011., 19:06   #7
Lika091
Lika091's Avatar
Postovi: 844
Riješio sam problem
TuneUP 2010 -> Customize Windows->Drivers->Advonced->Settings
A evo i uputa nekom ako hoće sakriti određeni disk ))
Staro 22.02.2011., 23:05   #8
Damanalovca
Postovi: 19
, hvala na uputi za rješavanje na tvoj način.
