Staro 02.06.2010., 01:19   #1
petar0001
Datum registracije: Apr 2009
Lokacija: split
Postovi: 9
(riješeno) lsass.exe greška kod bootanja Windowsa XP
Imam problem prilikom dizanja windowsa (xpsp3), prije desktopa mi javi ovu poruku i ne mogu nista. Samo restart. Ne pali safe mode, nema last good known....Sa Hirrens Boot-om mogu dignit mini xp i tada mi javi neku poruku upozorenja tipa 0xc0000005 (nije bsod).Windows Debugger mi javlja sljedece:
Debugging Details:
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
i onda onaj standardni tekst pa ispod njega ovo:
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: nt
FAULTING_MODULE: 804d7000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 48025eab
EXCEPTION_RECORD: f7c66a94 -- (.exr 0xfffffffff7c66a94)
ExceptionAddress: 80577e71 (nt+0x000a0e71)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 00000001
Parameter[1]: 0008a6bc
Attempt to write to address 0008a6bc
CONTEXT: f7c66790 -- (.cxr 0xfffffffff7c66790)
eax=e39660fc ebx=806f0744 ecx=0008a6b8 edx=e3966008 esi=e2b3cae0 edi=e39660d0
eip=80577e71 esp=f7c66b5c ebp=f7c66b98 iopl=0 nv up ei ng nz ac pe cy
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010297
nt+0xa0e71:
80577e71 ?? ???
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x24
LAST_CONTROL_TRANSFER: from 00000000 to 80577e71
STACK_TEXT:
f7c66b58 00000000 f7c66bd8 8054b587 f76af339 nt+0xa0e71
FOLLOWUP_IP:
nt+a0e71
80577e71 ?? ???
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt+a0e71
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntoskrnl.exe
STACK_COMMAND: .cxr 0xfffffffff7c66790 ; kb
BUCKET_ID: WRONG_SYMBOLS
Followup: MachineOwner
Napravio sam prije 2 dana Repair windowsa jer sam imao isti problem i radilo je. Danas sam isao share-at 3 particije (2 hdd-a) i prilikom share-anja d particije (hdd0) mi je jednostavno izbacio ponovo ovu poruku.
Moze li pomoc......
Zadnje izmijenjeno od: petar0001. 04.06.2010. u 23:59.
petar0001 je offline   Reply With Quote
Staro 02.06.2010., 03:06   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
Jesi skenirao komp kakvim "live" antivirusom?
Preporuka bi isla za Kaspersky live cd (skini, zaprzi bootaj i stavi full scan)..
Code:
Isass.exe - veliko slovo i = virus
lsass.exe - malo slovo l = systemski process (Local Security Authority Subsystem Service)
http://www.techmixer.com/free-bootab...download-list/
IE6
Linux is Not Windows
Staro 02.06.2010., 10:14   #3
petar0001
Lokacija: split
Postovi: 9
Joke, hvala na odgovoru. Probat cu i ovo, medjutim, meni je lsass.exe - malo slovo l =sistemski process. Sta bi tu moglo bit, do cega je? Jeli to neki mozda hardware-ski problem?
Staro 02.06.2010., 12:23   #4
Joke
N00B
Joke's Avatar
Postovi: 3,886
Prvo poskeniraj sa AV-om pa ces vidit, za ovaj error 0xc0000005 pogledaj tu na linku..
PS. Radio si repair ("gazio" si postojecu instalaciju), ili si napravio format i (clean install)?
IE6
Staro 02.06.2010., 21:24   #5
petar0001
Lokacija: split
Postovi: 9
Nisan sa AV-om nista pametno napravio. Napravija san repair, nisam format. Cak sam maloprije i clear-a cmos sa jumperom i vadija bateriju od bios-a. I nista. Zadnja sansa: upravo formatiram windowse. I, javija mi je prilikom kopiranja file-ova gresku, ne moze kopirat cinemst2.sys. Onda sam ubacio drugi cd sa win instalacijom i nastavio s njim. Inace, imam tri memorijska utora i tri modula. Svaku od memorija sam samu stavija u jedan utor, pa opet u drugi, treci, pa onda drugu memoriju isto, trecu....i proba dignit windowse. Javlja mi uvik istu gresku. Sad cu vidit kako ce mi se ponasat kad zavrsi nova instalacija na formatiranom disku pa cu javit sta se dogodilo.
Ma mislim da ovo nije virus nego sistemski problem, a stah me je da nije mozda maticna otisla iako mi je test pokaza da je sve ok....(hirrens boot). A vidit cemo.
Staro 04.06.2010., 23:58   #6
petar0001
Lokacija: split
Postovi: 9
Izgleda da je ram u pitanju....jedan je krepa i to je izgleda pravilo problem....Nadam se da je samo to ce sad bit ok.
