Staro 22.04.2010., 22:33   #1
bliss_zg
bliss_zg - take, muljanje na tržnici
Lokacija: ST
Postovi: 305
Postavljanje statickih ruta
Imam 3 routera(2811) i ISP router.
Ovo je tablica po kojoj bi trebao konfigurirati staticku rutu unutar mreze.
Moze mi netko reci kako?
Znam da je naredba IP ROUTE iz config moda, ali neznam koje tocno adrese trebam uzeti.
Zahvaljujem
bliss_zg je offline   Reply With Quote
Staro 22.04.2010., 23:13   #2
Raven_1
Night shift
Raven_1's Avatar
Datum registracije: Jul 2002
Postovi: 884
Autor bliss_zg Pregled postova
Zahvaljujem
Pospan sam, ali koliko vidim R3 je spojen na ISP, a R1 i R2 preko serial sucelja.
Znaci 192.168.101.0 i 192.168.102.0 idu via Serial0/1/0. Znaci ruta iz drugog routera se upisuje u onaj prvi (npr. u r1 upises ip route 192.168.102.0 255.255.255.0 int s0/1/0).
E da i ako nije definirano ako ne znas next hop gateway onda u R1 stavis ip route 0.0.0.0 0.0.0.0 S0/1/0.
Proc: AMD X2 3800+ cooled by TT BigTyphoon
Matična: ABIT AN8 SLI
RAM: 2x512MB OCZ Platinum EL rev2 PC3200
Grafička: SAPPHIRE ATI RADEON HD3450 256MB
HDD: WD 40GB i Samsung 160GB @ 7200
RW:DVD-ROM Pioneer DVD-106
PSU: 420W Xilence RedWing
"NOBODY expects the Spanish Inquisition! Our chief weapon is surprise...surprise and fear...fear and surprise.... Our two weapons are fear and surprise...and ruthless efficiency.... Our *three* weapons are fear, surprise, and ruthless efficiency...and an almost fanatical devotion to the Pope.... Our *four*...no... *Amongst* our weapons.... Amongst our weaponry...are such elements as fear, surprise.... I'll come in again."
--uoɥʇʎd ʎʇuoɯ--
Zadnje izmijenjeno od: Raven_1. 22.04.2010. u 23:19.
Raven_1 je offline   Reply With Quote
Staro 22.04.2010., 23:25   #3
bliss_zg
Lokacija: ST
Postovi: 305
Joj zab sam napisat.
R3 je spojen na ISP preko SERIALA i na switch preko FA
R2 je spojen na ISP preko SERIALA i na switch preko FA
R1 je spojen preko SERIALA na R2 i na switch preko FA
ma evo slika toga
http://www.imagesforme.com/show.php/...8_untitled.JPG
Staro 22.04.2010., 23:35   #4
bliss_zg
Lokacija: ST
Postovi: 305
R1(config)#ip route 192.168.102.2 255.255.255.0 192.168.100.2
R1(config)#ip route 172.16.3.6 255.255.255.0 192.168.100.2
R1(config)#ip route 176.16.3.2 255.255.255.252 192.168.100.2
R1(config)#ip route 172.16.3.0 255.255.255.252 192.168.100.2
R1(config)#ip route 172.16.3.4 255.255.255.252 192.168.100.2
R1(config)#ip route 172.168.103.1 255.255.255.252 192.168.100.2
R1(config)#ip route 172.168.103.1 255.255.255.0 192.168.100.2
R2(config)#ip route 192.168.101.0 255.255.255.0 192.168.100.1
R2(config)#ip route 172.16.3.6 255.255.255.252 172.16.3.2
R2(config)#ip route 172.168.103.1 255.255.255.0 172.16.3.2
R3(config)#ip route 172.16.3.2 255.255.255.252 172.16.3.5
R3(config)#ip route 192.168.102.1 255.255.255.0 172.16.3.5
R3(config)#ip route 192.168.101.1 255.255.255.0 172.16.3.5
ISP(config)#ip route 192.168.100.0 255.255.255.0 172.16.3.1
ISP(config)#ip route 192.168.101.0 255.255.255.0 172.16.3.1
ISP(config)#ip route 172.168.103.0 255.255.255.0 172.16.3.6
ISP(config)#ip route 172.168.102.0 255.255.255.0 172.16.3.1
ISP(config)#ip route 192.168.102.0 255.255.255.0 172.16.3.1
evo ovako sam sad satvio i pinga se sve...jel ovo ok?
Staro 23.04.2010., 00:39   #5
bliss_zg
Lokacija: ST
Postovi: 305
Evo pinga se sve pa pretpostavljam da je ovo gore navedeno ok.
Jos jedno pitanje, jel zna netko kako bi konfigurirao PPP nizeg stupnja na ovu mrezu?
Staro 23.04.2010., 20:10   #6
shimpa
PC Ekspert
shimpa's Avatar
Lokacija: localhost
Postovi: 1,012
tu je kaos
1) nigdje ne vidim da imaš 172.168.x.x mrežu pa pretpostavljam da je to typo u configu.
2) rute možeš sumirati, ne moraš pisati za svaku /30 mrežu rutu za sebe, ako su "u istom smjeru" sumariziraj ih (ili koristi default rutu pametno)
3) ip route 192.168.102.2 255.255.255.0 192.168.100.2 nije ispravno upisano (vjerojatno svejedno radi, IOS to ispravi on the fly), ispravno bi bilo 192.168.102.0 .......
4) ip route 172.16.3.6 255.255.255.0 192.168.100.2 isto
5) ip route 172.168.103.1 255.255.255.0 192.168.100.2 isto
i toga ima još. da ne pišem svaki za sebe evo config
r1: ip route 0.0.0.0 0.0.0.0 192.168.100.2
r2: ip route 192.168.101.0 255.255.255.0 s0/1/0
r2: ip route 192.168.103.0 255.255.255.0 s0/2/0
r2: ip route 0.0.0.0 0.0.0.0 s0/2/0
r3: ip route 0.0.0.0 0.0.0.0 s0/1/0
isp: ip route 192.168.101.0 255.255.255.0 s0/2/0
isp: ip route 192.168.102.0 255.255.255.0 s0/2/0
isp: ip route 192.168.100.0 255.255.255.0 s0/2/0
isp: ip route 192.168.103.0 255.255.255.0 s0/1/0
eto.
ne znam što misliš pod ppp nižeg stupnja iskreno
EDIT: typo
Zadnje izmijenjeno od: shimpa. 23.04.2010. u 21:12.
shimpa je offline   Reply With Quote
Staro 25.04.2010., 21:15   #7
bliss_zg
Lokacija: ST
Postovi: 305
Pise mi samo u zadatku da aktiviram PPP zastitu nizeg stupnja. :/
Staro 25.04.2010., 21:49   #8
newalss
Raindrops keep fallin'...
newalss's Avatar
Lokacija: Đakovo
Postovi: 826
A vjerojatno se misli na postavljanje aux i console passworda iz config-line dijela.
Enable secret šifra iz config moda bi vjerojatno bio viši stupanj jer bolje enkriptira šifru.
"I told my parents that when I grew up I wanted to be a musician.They said it had to be one or the other"
newalss je offline   Reply With Quote
Staro 25.04.2010., 22:14   #9
bliss_zg
Lokacija: ST
Postovi: 305
1. -Zabraniti bilo kakav promet sa mreže 192.168.102.0/24 na mrežu 192.168.103.0/24.
2. -Sa hosta čije je IP adresa 192.168.103.100 zabraniti promet ne mrežu 192.168.101.0/24. Napomena: Ovaj host nije ucrtan u topologiji.
Ovo bi mi trebalo jos, pa ako netko moze napisati konfig.
Molim vas, stvarno je hirno
Jel zna netko postaviti ACL za dvije mreze?
Zadnje izmijenjeno od: bliss_zg. 26.04.2010. u 22:16.
Staro 25.04.2010., 22:35   #10
kill
Datum registracije: Jun 2003
Postovi: 533
pa jel imaš kakve materijale? ovo se sve da prokužit odmah iz primjera u materijalima...
kill je offline   Reply With Quote
Staro 25.04.2010., 22:42   #11
bliss_zg
Lokacija: ST
Postovi: 305
Autor kill Pregled postova
Imam al ne prihvaca mi, ili nisam dobro shvatio.
odem u R3 i stavim access-list 10 deny 192.168.102.0 0.0.0.255
i ne prihvaca ga kao marker nesto...
Staro 25.04.2010., 23:45   #12
bliss_zg
Lokacija: ST
Postovi: 305
Sto se tice PPP-a, treba aktivirati PAP.
radio sam na sljedeci nacin
R1#configure terminal
R1(config)#interface serial 0/1/0
R1(config-if)#encapsulation ppp
R1(config-if)#ppp authentication pap
R1(config-if)#ppp pap sent-username router password skola
I postupak ponovio za svaki router, ali ne radi.
Moze mi netko malo to objasniti?
Zahvaljujem
Staro 26.04.2010., 22:26   #13
bliss_zg
Lokacija: ST
Postovi: 305
Staro 27.04.2010., 10:38   #14
shimpa
PC Ekspert
shimpa's Avatar
Lokacija: localhost
Postovi: 1,012
R2:
conf t
access-list 10 deny 192.168.102.0 0.0.0.255 192.168.103.0 0.0.0.255
access-list 10 permit any any
int fa1
ip access-group 10 in
R3:
conf t
access-list 10 deny host 192.168.103.100 192.168.101.0 0.0.0.255
int fa1
vi to učite konfiguraciju cisco routera u školi ili je to cisco akademija ili što je?
