bycod
Lokacija: Zagreb / Dubrava
Postovi: 6,699
Teac cd-rw nece da przi normalno
Evo kako naslov kaze przilica ima faking pms jer kada oce przi dobro a kada nece neprzi nis ili mi sjebe cd-e. E sada evo loga i plz ekipa pomozite dok ju nisam od zid zvizno a trebam poprziti masu stvari.... Posto sam vidio da je rak-china sam svoj majstor bio bi mu JAKO zahvalan da baci neki komentar . slika ![]() log 14:24:29 #13 Text 0 File ThreadedTransferInterface.cpp, Line 994 Removed 2 run-out blocks from end of track 1. Length: 297330 -> 297328. 14:24:29 #14 Phase 24 File dlgbrnst.cpp, Line 1800 Caching of files started 14:24:29 #15 Text 0 File Burncd.cpp, Line 4073 Cache writing successful. 14:24:29 #16 Phase 25 File dlgbrnst.cpp, Line 1800 Caching of files completed 14:24:29 #17 Phase 28 File dlgbrnst.cpp, Line 1800 Speed measurement started 14:24:29 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 14:24:44 #19 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 14:24:44 #20 Text 0 File dlgbrnst.cpp, Line 1658 Set remaining time: 0:00,000 (0ms) -> OK 14:24:44 #21 Phase 29 File dlgbrnst.cpp, Line 1751 Speed measurement completed: 266.5x (39.976 KB/s) 14:24:44 #22 Phase 32 File dlgbrnst.cpp, Line 1800 Simulation started at 10x (1.500 KB/s) 14:24:44 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 14:24:44 #24 Text 0 File Mmc.cpp, Line 19487 Set BUFE: supported -> ON , SMART-BURN : ON 14:24:52 #25 SCSI -1135 File Cdrdrv.cpp, Line 1431 SCSI Exec, HA 1, TA 2, LUN 0, buffer 0x040D0000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0x2A 0x00 0x00 0x00 0x0A 0x20 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x0C 0x00 14:24:52 #26 CDR -1135 File Writer.cpp, Line 301 Write error 14:24:52 #27 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 14:24:52 #28 Text 0 File ThreadedTransfer.cpp, Line 223 conversion idle, stopping reader 14:24:52 #29 CDR -201 File WriterStatus.cpp, Line 154 Invalid write state TEAC CD-W552G\H1 T2 14:24:52 #30 TRANSFER -18 File WriterStatus.cpp, Line 154 Could not perform EndTrack 14:24:52 #31 Text 0 File dlgbrnst.cpp, Line 1658 Set remaining time: 0:00,000 (0ms) -> OK 14:24:58 #32 Phase 34 File dlgbrnst.cpp, Line 1800 Simulation failed at 10x (1.500 KB/s) Existing drivers: File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 20.12.2004 19:37:14 (Prassi/Veritas driver for win 2K) File 'Drivers\nvatabus.sys': Ver=5.10.2600.0446 built by: WinDDK, size=79360 bytes, created 3.6.2004 10:40:46 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
