Staro 31.03.2010., 12:50   #1
bedess_madrfakr
Datum registracije: Aug 2009
Postovi: 76
Question (riješeno) uTorrent poteškoće sa skidanjem torrenta
Ovo mi se prvo počelo pokazivati na BitTorrentu,mislio da je kriv program pa stavio uTorrent i ista stvar.
Zna netko u čem je fora i kako napraviti da mi nastavi skidati torrent?Zbunjuje me što mi neizbaci ovu grešku u početku nego nakon nekog vremena skidanja....dok skida sve radi kako treba.Full brzina i ostalo sve normalno....
bedess_madrfakr je offline   Reply With Quote
Staro 31.03.2010., 13:06   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
IE6
Linux is Not Windows
Staro 31.03.2010., 13:19   #3
bedess_madrfakr
Postovi: 76
Autor Joke Pregled postova
thx budem vidio hoće ovo pomoći.
Staro 31.03.2010., 13:23   #4
Joke
N00B
Joke's Avatar
Postovi: 3,886
The problem is AVG and other on-demand virus scanners. I've found a fix to this that allows you to still scan the file when it's done downloading and doesn't involve modifying your virus scanner.
Simply go into the uTorrent options and select "Append .!ut to incomplete files" if this is activated then the files uTorrent is still downloading have an extension that AVG does not scan as part of its virus shield activities, however the .!ut is removed when the file is fully downloaded thus allowing AVG to "see" the file and scan it. By using this option you should not encounter the error anymore and still be protected when downloading torrents.
Enjoy!
Autor bedess_madrfakr Pregled postova
Pa jesi pogledao ista?
Iako je "nepoznato" koji AV koristis itd. tako da bi bilo dobro da reces..
Pogledaj ovo ->
Enjoy!
IE6
Staro 31.03.2010., 13:28   #5
bedess_madrfakr
Postovi: 76
Just select "Append .!ut to incomplete files" and you are done. Problem solved.
You can select this under Options > Preferences > General > "When Downloading" section.
riješenje problema.
Hvala puno.
