Staro 26.03.2010., 01:32   #1
wayfarer
Datum registracije: Mar 2010
Postovi: 39
(riješeno) USB wireless adapter driveri za Windows 7
Bok,
nemogu nikako pokrenut usb wireless adapter na windowsima 7, x86.
Imam d-link DWL-G122...
Na google ništa konkretno...
Ima rješenja?
Ako ne treba bi preporuka usb adaptera koji se normalno instalira na 7-ici.
Hvala, poz
Dogs are the leaders of the planet. If you see two life forms, one of them's making a poop, the other one's carrying it for him, who would you assume is in charge.
wayfarer je offline   Reply With Quote
Staro 26.03.2010., 09:44   #2
Postovi: 34,066
Zamijeni usb wlan adapter pci wlan karticom pa nećeš imati problema.
Staro 26.03.2010., 09:53   #3
Thorax
Doomster
Thorax's Avatar
Datum registracije: Mar 2008
Lokacija: Kraj Donji
Postovi: 400
Imao sam isti taj i nije bilo nikakvih problema na 7-ici... sama je našla drivere i radio je bez problema.
Nakon D-linka sam imao Airlive WL1600, puknuo drivere za Vistu i opet je radio bez problema.
CPU: AMD Athlon 640 under TX3
MBO: Asrock 870 Extreme3
RAM: 8 GB DDR3 Mushkin @ 1333, CL8
VGA: XFX HD4830
HDD: WD 6400AAKS
Monitor: Samsung 2470H
PSU: Fortron PNF 400W
OS: Win 7 Enterprise x64 SP1
Net: 12 Mbit/1,25 Mbit
Sound: Logitech X-530
CPU: Intel Celeron T3100
MBO: HP 1526
RAM: 2 GB DDR3
VGA: GMA 4500MHD
HDD: WD3200BEVT
Monitor: 15,6“ LCD
PSU: HP 65 W
OS: Win 7 Enterprise x86 SP1
Sound: Arctic Sound P281
CPU: AMD Athlon M320 undervolt @ 0.975 V
MBO: AMD 785
RAM: 2 GB DDR2 800
VGA: Integrated HD4200
HDD: Hitachi 250 GB
Monitor: LCD 15,6“
PSU: Delta Electronics 65 W
OS: Win 7 Ultimate x86
Net: 8 Mbit/768 kbit
Sound: integrated
Thorax je offline   Reply With Quote
Staro 26.03.2010., 11:13   #4
Thommy
Thommy's Avatar
Postovi: 469
koje drivere koristis???
pogledaj koja ti je revizija w-lan adapter
odi na d-linkovu stranicu u skini drivere za Vistu jer mislim da za win7 nema drivera i instaliraj te drivere od viste i trebalo bi proraditi
Thommy je offline   Reply With Quote
Staro 26.03.2010., 11:25   #5
wayfarer
Postovi: 39
Probao sam da ih sam instalira i ništa.
Gledao sam na njihovoj stranici, drivere za Vistu iuopce nemaju, pise da su Vista, kad ih se skine pise XP i ne rade.
Staro 26.03.2010., 11:33   #6
Thommy
Thommy's Avatar
Postovi: 469
koja revizija ti je wlan adapter?
Staro 26.03.2010., 11:40   #7
wayfarer
Postovi: 39
H/W Ver: C1 f/W Ver: 3.30 (E)
Staro 26.03.2010., 11:48   #8
Thommy
Thommy's Avatar
Postovi: 469
evo link neznam dali si sa tim driverima probao, ako nisi probaj najprije ove od 16/06/2009, ako nece sa njima imas 2 verzije od 09/03/2007 pa probaj sa njima ... velim ja sam uspio sa tim driverima upogoniti te Dlinkove wlan adaptere
Staro 26.03.2010., 12:25   #9
wayfarer
Postovi: 39
Radi s tim driverima
