Staro 28.02.2010., 23:49   #1
mzex
Lokacija: Varazdin
Postovi: 72
sharing problem
Bok!
imam dva kompa oba sa windowsima 7. desktop je ppovezan sa kablom a laptop wireless.
Namjera je da djelim fajlove sa desktopa, pa sam sa desnim klikom ->share postavil d se e: i y: shareju.
Oba ih vidim i mogu im pristupiti osim e:\+mp3. javlja mi da moram kontaktirati administratora da bi imal ovlasti pristupiti mu.
moje advanced sharing settings su:
_ network is home network
_ turn on network discovery
_ turn on file nad printer sharing
_ turn on sharing so anyone with network access can read and write files in the public folders
_ all the media is clicked under media streaming
_ enable file sharing for devices that uses 40- or 56-bit encryption
_ turn off password procetced sharing
_ allow windows to manage homegroup connections
isto je na oba kompa.
drugi problem je da preko laptopa nemrem brisati il pisati fajlove na tim diskovima (diskovi na desktopu). namestil sam ih na read i write po sharing opcijama, al mi svejedno neda da to radim.
kad ih probam izbrisasti dobim obavjest:
you require permission from S-1-5-21-2669962211-865993366-3033801785-500 to make change to this file
Jedino kad dobim ovlasti je kad svaki folder posebno shaream, a to mi se bogme neda. S tim da +mp3 folder ni onda nije dostupan.
What can I do?
mzex je offline   Reply With Quote
Staro 01.03.2010., 14:08   #2
mahoona
mahoona's Avatar
Postovi: 284
Autor mzex Pregled postova
What can I do?
You can check NTFS permissions on all those shared folders. Also, try not to share complete drive, but only folders. And when you set NTFS permissions, there is a checkbox for replacing all child objects permissions......so you won't have to change it on every single folder.
Ak buš zapel, mogu i na rvackom, ni problem
mahoona je offline   Reply With Quote
Staro 01.03.2010., 17:32   #3
mzex
Lokacija: Varazdin
Postovi: 72
Autor mahoona Pregled postova
pisal sam ovaj post i na jednom engleskom forumu pa mi je what can I do ostal nepreveden.
hm. nego gde su ti NTFS presmissions?
P.S.: u tome i je stvar da ja hocu celi folder šerati.
Staro 01.03.2010., 17:39   #4
mahoona
mahoona's Avatar
Postovi: 284
Desni klik na folder i onda Properties i tab Security, tu definiraj prava koja trebaš i još možeš na tom prozoru otići pod Advanced i tamo čekirati da se prava spuste sa tog foldera na sve foldere pod njim.
