Lokacija: Opatija(pobri)
Postovi: 38
Ajde pliz ljudi imam problem sa blodlinesom,na levelu society of leopold 3 kada trebam pobjeć van iz spilje sa gumenjakom igra mi se sruši,i tako svaki put.Sruši se kada se počne loadat idući level?i tako svaki jebeni put na istom mjestu i ja nemogu dalje igrat? Igra nije oreginal. Pliz help!!!!
"One bright morning when my work is over I will fly away home" Bob Marley StreetSajla Forum |
Postovi: 38
Evo i eror report Danas neću moć vidjet odgovore,ali ako još šta treba sutra ću dodat! Hvala * * * Vampire Crash Data Log, Generated From Exe Built On: Oct 6 2004 * * * vampire caused an Access Violation (0xc0000005) in module vampire.exe at 001b:00000001. Read from location 00000001 caused an access violation. Context: EDI: 0x00000001 ESI: 0x00000000 EAX: 0x00000001 EBX: 0x00000000 ECX: 0x0012e9f8 EDX: 0x20b42dd8 EIP: 0x00000001 EBP: 0x2009acb6 SegCs: 0x0000001b EFlags: 0x00010202 ESP: 0x0012e784 SegSs: 0x00000023 Bytes at CS:EIP: ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? ?? -----[ SysInfo ]----- Error occurred at 2/19/2004 10:40:12. 1 processor(s), type 586. 99% memory in use. 512 MBytes physical memory. 4 MBytes physical memory free. 931 MBytes paging file. 75 MBytes paging file free. 2048 MBytes user address space. 1106 MBytes user address space free. -----[ StackTrace ]----- 0x20D5E078 : ?F@@YAXPAPAVIEngineAPI@@@Z in D:\vampire\bin\engine.dll 0xCE8B5501 : <unknown symbol> in <unknown module> -----[ ScopeTrace ]----- SCOPE_TRACE data, stack depth = 3 02. RunListenServer () 01. CEngineAPI::Run () 00. LauncherMain () -----[ ModuleList ]----- Module 1 D:\vampire\vampire.exe Image Base: 0x00400000 Image Size: 0x00017000 Checksum: 0x00000000 Time Stamp: 0x4164cd8f File Size: 1298432 File Time: 12/6/2004 22:30:30 Module 2 D:\vampire\bin\vstdlib.dll Image Base: 0x10000000 Image Size: 0x00018000 Checksum: 0x00000000 Time Stamp: 0x4164cbb9 File Size: 94268 File Time: 10/6/2004 22:11:44 Module 3 D:\vampire\bin\tier0.dll Image Base: 0x10000000 Image Size: 0x00034000 Checksum: 0x00000000 Time Stamp: 0x4164cbb5 File Size: 180280 File Time: 10/6/2004 22:11:44 ....ovo dole ide u nedogled
Postovi: 2,458
Ima vise rjesenja ovog problema/bug-a kojima uzgrd receno ova igra nazalost obiluje: -Prvi je manje zahtjevan i svodi se na instalaciju sluzbenog patcha ver1.2 s ovog linka -Drugi je objasnjen na ovom forumu link -Inace se rjesenje takvog i slicnih problema najlakse nade ovako link googlajte ljudi goooglajte! ![]() |
Postovi: 38
Hvala kompa
