Lokacija: Enemy Territory
Postovi: 210
Delete...
Kako mogu zbrisat file s desktopa,poceo sam skidat torrent s neke stranice i nisam ga skinuo so kraja,i sad mi stoji na desktopu i ne mogu ga zbrisat restartao sam komp i opet nis i dalje je tam...kak to zbrisat?
It s Nice To be Important,But More Important is to be nice...... |
Lokacija: Constantinopolis
Postovi: 1,002
kristalna kugla mi je ostala u gepeku, pa ću te pitati isto što i na indexu: kakav error/poruku ti jave windowsi kada ga pokušaš obrisati? ![]() |
Postovi: 210
Napise ovo: Cannot delete MVW-MPEG2-OZSXIDIZFIDHWC:It is being used by another person or program.Close any programs that might be using the file and try again.
#4 | |
Postovi: 560
#5 | |
Datum registracije: Aug 2003
Postovi: 3,193
![]() "Well windows seem to have a REALLY big problem when it comes to reading AVI files. It seems that when you click on an AVI file in explorer, it'll try to read the entire AVI file to determine the width,height, etc. of the AVI file (this is displayed in the Properties window). Now the problem with Windows is that if you have a broken/not fully downloaded AVI file that doesnt contain this info, Windows will scan the entire AVI file trying to figure out all these properties which in the process will probably cause 100% CPU usage and heavy memory usage. To solve this problem all you have to do is the following: 1. Open up regedit 2. Goto HKEY_CLASSES_ROOT\SystemFileAssociations\.avi\shellex \PropertyHandler 3. Delete the "Default" value which should be "{87D62D94-71B3-4b9a-9489- 5FE6850DC73E}" Voila! Please not that this will no longer provide you with the windows properties displaying the AVI file information such as width, height, bitrate etc. But its a small price to pay for saving you resources |
#6 | |
Rider of the Storm
Lokacija: Hacienda, Vodice
Postovi: 204
Evo častin te pivom Živija!
Dobra vila mi je ispunila dvije želje. Treći put nisam mogao |
Postovi: 210
I dalje neide,probao sam ono s registijem al nis od tog.Sad sam mu samo stavio da bude Hidden da mi ne bi zauzimao mjesto na desktopu.....
Postovi: 1,002
earth to izopaceni!!!1 datoteka ti je još uvijek na desktopu, nema veze kaj je ti ne vidiš. slikopisna prispodoba: u dubrovniku si i gledaš nosač aviona usidren nedaleko. staviš si škaniclu na glavu i više ne vidiš taj nosač aviona, ali ON JE JOŠ UVIJEK TAMO!!!1 go figure. ![]() anyways, jesi li probao bootati u SafeMode i zatim obrisati datoteku? u najgorem slučaju, možeš ga obrisati pomoću recovery konzole, ako se ne varam. ![]() |
#10 | |
Postovi: 210
Datum registracije: Sep 2004
Lokacija: Sarajevo
Postovi: 147
Ima vrlo jednostavno rjesenje. Ako vec nemas, svakako bi trebao imati instaliran Window Washer. Koristan program za ciscenje ostataka surfanja, temp fajlova i slicnih gluposti. Naravno imas mogucnost da odaberes sta da cisti a sta ne. Eh ovaj programcic ti u toku instalacije pored osnovnog programa doda i jednu korisnu funkciju kloja se javlja na desnom kliku "Shred (Wash with bleach)". Kliknes desnim na taj fajl, odaberes ovu funkciju i nema mu spasa.
bhtech.org/forum |
