Staro 17.02.2005., 01:38   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATI Proprietary Linux driver version 8.10.19
Pingoljupci-evo vam i novih drivera
ATI has released new Proprietary Linux Driver today (February 16, 2005). Driver version is 8.10.19 and it is available for x86 and x86_64 platforms.
Issues Resolved
This section provides information on issues that have been resolved with the latest release of the ATI Proprietary Linux driver. This includes the following:
Starting X on a DVI display no longer results in noisy or flickering output with some displays
The Monitor autodetect no longer finds a phantom CRT display if none is connected either RADEON™ X800, X700, X300, or FireGL™ V5100, and V5000
The ATI Proprietary Linux driver now works with Apple Cinema display flat panels in single link mode
fglrxconfig now produces a proper xorg.conf X Server configuration file
Running certain 3D applications no longer result in system hangs on x86_64 systems with RADEON™ 9100/8500 series or FireGL™ 8800 installed
Kernel Module Driver compile support for Kernel 2.6.10 lbb
XVideo support now available in dualhead configuration lbb
3D geometry corruption no longer occurs with Celestia and other 3d apps
A blank screen or X failing to load and returning to the console no longer occurs under X.Org 6.8 when using the config file generated by fglrxconfig
64 Bit systems with 4 or more GB of RAM no longer hang the system while loading the X Server
Full release notes:
http://www2.ati.com/drivers/linux/linux_8.10.19.html
x86 driver:
http://www.ati.com/support/drivers/l...4&submit=GO%21
x86 64:
http://www.ati.com/support/drivers/l...1&submit=GO%21
Staro 17.02.2005., 21:05   #2
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,346
Prvi dojmovi:
fgl_glxgears 796 FPS
glxgears 4154 FPS
Quake3 1024x768 full details timedemo/demo four sa zvukom 200 FPS
Prosječno preko 200 FPS po mapi (od 180-400 FPS)
Konfiguracija iz siga, Slackware 10, 2.6.10 kernel + fglrx_4_3_0-8.10.19-1 (eksterni agp gart -> nvidia gart)
Dosta primjetan skok performansi u odnosu na prošle verzije.
Staro 17.02.2005., 23:09   #3
Jelc
Super Moderators
Postovi: 17,485
Pa ide to polako na bolje
Čak je tip koji je zadužen za izradu drivera inicirao otvaranje posebnog foruma za pingoljupce na driverheavenu kako bi se brže rješavali problemi i oni dobili kvalitetniju povratnu informaciju.
Forum za Linux Radeon Display Drivers:
http://www.driverheaven.net/forumdisplay.php?f=103
Staro 20.02.2005., 11:29   #4
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,346
ATi pod Linuxom - sve manje loš
Prošlog je tjedna ATi izdao novu verziju pogonitelja za svoje Radeon kartice pod Linuxom. Binarni paket nosi oznaku 8.10.19, a možete ga pronaći ovdje i to u verzijama za XFree86 i X.Org (6.8) grafičke podsustave (ili kao paket za vašu omiljenu distribuciju). Nova verzija predstavlja ugodno iznenađenje ne samo zato što je već druga od početka godine (što nam daje naslutiti kako su u ATi-ju možda i mislili ozbiljno kad su najavili ozbiljniju driversku podršku pod Linuxom), nego i zato jer 8.10.19 u odnosu na verziju iz prošlog mjeseca (8.8.25) donose niz bitnih poboljšanja te ubrzanje izvođenja OpenGL aplikacija i do 40% - što je posebno uočljivo u igrama kao što su Quake 3, Doom 3 ili UT2004.
Od popravaka, vrijedi istaknuti kako automatsko detektiranje više ne pronalazi fantomski CRT monitor, a ispravljena je i korupcija geometrije koja se očitovala kao "pucanje" tekstura i poligona u Celestiji i drugim 3D aplikacijama.
Vrijedi napomenuti kako, prema našem iskustvu, novi driveri zahtijevaju 2.6.10 kernel zbog izmijenjenog naziva jedne od funkcija, te se odbijaju kompajlirati uz 2.6.9 verziju.
http://www.bug.hr/vijesti/index.asp?id=61933
