Staro 12.02.2005., 01:17   #1
Mr. Nice
Mr. Nice's Avatar
Datum registracije: Sep 2004
Postovi: 357
Kakav je capturing 9800se All In Wonder ?
Zanima me kakva je kvaliteta capturinga ATI 9800se All In Wonder, tj da li je bolja od prosječne TV-kartice, recimo Leadtek Winfast 2000XP Deluxe? Uvjerio sam se da je Winfast dosta bolja od recimo K-world (shit-card).
Razmišljao sam o Pinnacle AV/DV (dakle samo capturing) pa su tu uletile neke lude kombinacije i došao sam do ideje o 9800seAIW.
Malo sam surfao i "Rage Theater 200" mi se i ne čini tako loš:
(paste)
• Decode video from a wide range of sources, including broadcast video, DVD and S-VHS
• Accepts and outputs S-Video, Composite and HD Composite (HDTV) signals
• Decode all PAL, NTSC and SECAM discrete video formats
• Decode from multiple inputs including Y:Pr:Pb component input and a combination of compostite and S-Video sources
• Supplies dual 12-bit analogue to digital processors for decoding analogue video input
• Cleanup of noisy video signals using AGC and Clamp methods • 2D Comb filter and horizontal and vertical video downscalers
• Macrovision detection and filtering
• Demux and split all broadcast television audio signals into discrete stereo
• 16-bit sampling at 32kHz, 44.1kHz, 48kHz and 96kHz
• Decodes second language audio transmissions
• Modulation of volume based on signal strength
________________________________________________
Philipsov tuner je (kažu) rađen po ATI-jevim specifikacijama i trebao bi biti bolji od 71?? (onog koji koristi WInfast2000).
Mislim da Pinnacle AV/DV koristi 10-bitne procesore, ali nisam siguran jer mi se sve več brka u glavi.
Sve u svemu za te nofce mogu dobiti Pinnacle 9 AV/DV, dodati još cca 50% za neku Canopus karticu ili uzeti neki jeftini DVD-rekorder.
Još jedan razlog je što imam priliku prodati 9200SE za 300 kuna , 256 kingmaxa@400 za 300, Winfast2000XP za cca 400 kn.
Što se tiče igračkih sposobnosi 9800se - boli me briga, 9200se mi je bila dovoljna jer igram tetris i wormse.
Drugi je što je 100% kompatibilna s Pinnacle Studio 9 softverom.
Teći- manja mogučnost IRQ problema koje voli raditi Pinnacle AV/DV na VIA-chipsetima.
(2 i 3 su trabunjanja sa različitih foruma, a ja imam KT-600)
Dakle ako mislite da je capturing bolji od prosjeka tv-kartica, dakle za neku kvalitetniju amatersku upotrebu, olakšajte mi muke jer nočima čitam koješta po forumima i ima takvih sra__a, da ti pamet stane.
Vidim da neki koriste ovu karticu pa me zanima prvenstveno njihovo mišljenje, a i drugih naravno.
E jesam ga nadrobio, a sada si mislite kak je meni u glavi. Napalio sam se, ali ne bih htio baciti 1300 kn ak ne dobijem nešto bolji captiring.
Hvala na razumjevanju - več sam dosadan sam sebi !
Mr. Nice je offline   Reply With Quote
Staro 12.02.2005., 14:57   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Sve AIW ali i Tv-kartice su dosta osjetljive na kvalitetu signala.
Ako imaš kvalitetan signal-i sa osrednom karticom ćeš moći imati kvalitatan capture.
Ovo sa VIA-chipsetom je bedastoća, prije će ti se desiti da imaš problema sa NF2 nego sa KT400/600.
Takva su bar moja iskustva sa Pinnacle PCTV PRO.
Mislim-meni je delala fino i na KT400/600 i na NF2, opet-dosta se ljudi prije žalilo da im dela probleme na NF platformi...
Ako ti igre nisu prioritet-bolje je imati odvojeno grafu i TV-karticu
A AIW je teže prodati...
Staro 17.02.2005., 18:34   #3
Izopaceni
Izopaceni's Avatar
Lokacija: Enemy Territory
Postovi: 210
Ovisi o cjeni....Ak kosta vise od 2000kn ne isplati se,jer ti je onda moze kupit TV karticu kojoj je u principu bas i namjena capturanje i prek TV kartice bi ti trebalo ispast bolje nego preko Radeonke,i jos mi se ne svida oznaka SE
It s Nice To be Important,But More Important is to be nice......
Izopaceni je offline   Reply With Quote
Staro 21.02.2005., 16:07   #4
Mr. Nice
Mr. Nice's Avatar
Postovi: 357
Našao sam ju za 1200 kn novu, a vjerojatno ću uzeti rabljenu (1 mj), dakle trebala bi biti ispod (ili max) 1000 kn.
Uskoro ostajem bez svoje 9200SE, a Leadtek Winfast već ima osigurano drugo mjesto. Tako da bi mi to bila zanimljiva varijanta, sve u jednom.
Ono SE me i ne brine previše jer je 256-bitna, a toliki sam gamer da mi je i 9200se bila ok.
Drugi mali plus je što je kompatibilna sa Pinnacle Studiom glede capturinga, dok ova moja nije. Pinnacle mi se od svega što sam probao, najviše sviđa.
A i pošto radim od jutra do mraka, bio bi red da se počastim nekim komadičem hardvera.
VIše me je brinulo neko loše mišljenje ili iskustvo s tom karticom, a za sada svi kažu isto, tj da je ok. Nisam čuo ništa loše o njoj.
A vjerojatno budem vidio za koji tjedan kada to sve postane aktualno, kako to "čudo u jednom" snima, pa vam javim.
Za sada su sve opcije otvorene pa bum još malo gruntal. A i ponekada je veči gušt kupovati i razmišljati, od same kupovine.
Ma nisam ni sam pametan, idem na zahod malo porazmislit o svemu tome.
Staro 25.02.2005., 17:22   #5
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Postovi: 1,163
hehehehehe
Izopačeni, baš me zanima gdje si čuo one stihove u sigu?
JVC HX-Z10 je offline   Reply With Quote
Staro 26.02.2005., 15:08   #6
Mr. Nice
Mr. Nice's Avatar
Postovi: 357
Nisu to stihovi, to je surova istina !
