Staro 04.12.2009., 13:21   #1
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,798
Koji prog za backup
...trebam neki prog za svakodnevni backup i nešto što može napraviti backup OSa koji je u raidu i po potrebi ga vratiti u prvobitno stanje
tintin je online   Reply With Quote
Staro 04.12.2009., 21:38   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
Za svakodnevni backup mozes se posluzit doticnim iz ove teme -> http://forum.pcekspert.com/showthread.php?t=156180
A sto se tice backupa OS-a (napravis ga i imas image postelanog/slozenog OS-a), mozes iskoristit Acronis true image.
IE6
Linux is Not Windows
Staro 04.12.2009., 21:53   #3
tintin
tintin's Avatar
Lokacija: negdje
Postovi: 1,798
Ako složim windowse u raid polje ima li to kakve veze sa backupom particije i eventualnim vraćanjem iste u slučaju greške?
...radi li acronis sa raid poljima ili to nema veze
Staro 04.12.2009., 22:16   #4
fre@k
fre@k's Avatar
Lokacija: osijek
Postovi: 1,887
CPU: I5 2500k
GPU: MSI TF 660 OC
MBO: Asrock Z68 PRO3
RAM: 2x4gb G. Skill (1333mhz)
PSU: Seasonic 620W
CASE: CM Elite 370
fre@k je offline   Reply With Quote
Staro 05.12.2009., 02:19   #5
Joke
N00B
Joke's Avatar
Postovi: 3,886
6) Do Acronis True Image and Acronis Disk Director programs support RAID arrays?
Yes Acronis True Image and Acronis Disk Director programs support all RAID arrays in Windows and almost all under Acronis bootable disc. There is a probability that Linux drivers (Acronis bootable disc is based on Linux) for a specific RAID array have not been included yet. You can use a special plug-in for the BartPE instead of the standalone version. This plug-in allows you to use Windows drivers for the RAID array when running Acronis True Image from BartPE bootable CD. See page 3 of Step-by-step instructions to create BartPE bootable disc.
-Frequently Asked Questions
-Create BartPE bootable disc
IE6
