Staro 22.01.2005., 00:08   #1
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Datum registracije: Sep 2004
Postovi: 1,163
problem sa 'prepoznavanjem' Harda
evo imam u ladici WD 20GB na NTFS particiji, nakratko sam ga zamijenio sa jednim na FAT32, kad sam kasnije vratio WD 2o Windows XP SP1 misli da Hard nije formatiran?
Zašto?
JVC HX-Z10 je offline   Reply With Quote
Staro 22.01.2005., 14:41   #2
Cataphract
Cataphract's Avatar
Lokacija: Constantinopolis
Postovi: 1,002
ne kužim pomoću čega pristupaš tom disku.. :confused: windows explorera, ili kako?
nedavno sam imao problema s jednim diskom, a otklonio sam ih na slijedeći način:
: right click My Computer : Manage
: pod Storage odaberi Disk Management
: u desnom prozoru desni klik na taj disk : Import Foreign Disk
to je jedino kaj mi trenutno pada na pamet. evo što kaže Help:
The Foreign status occurs when you move a dynamic disk to the local computer from another computer running Windows 2000, or Windows XP Professional. The Foreign status can also occur on computers running Windows XP Home Edition that are configured to dual-boot with another operating system that uses dynamic disks (such as Windows 2000 Professional). Dynamic disks are not supported on Windows XP Home Edition or on portable computers. A warning icon appears on disks that display the Foreign status.
To access data on the disk, you must add the disk to your computer's system configuration. To add a disk to your computer's system configuration, import the foreign disk (right-click the disk and then click Import Foreign Disks). Any existing volumes on the foreign disk become visible and accessible when you import the disk. For instructions describing how to move and import disks, see To move disks to another computer.
In Windows XP Home Edition you cannot access data on the disk, but you can convert the disk to a basic disk so that you can use the disk. Converting a dynamic disk to a basic disk destroys all data on the disk.
Warning
Do not convert a dynamic disk to a basic disk unless you are certain that you no longer need the data on that disk.
To convert the disk to an empty basic disk, see To change a dynamic disk back to a basic disk.
In some cases, a disk that was previously connected to the system can display the Foreign status. Configuration data for dynamic disks is stored on all dynamic disks, so the information about which disks are owned by the system is lost when all dynamic disks fail.
For instructions describing how to fix disks with Foreign status, see Troubleshooting.
Cataphract je offline   Reply With Quote
Staro 23.01.2005., 14:37   #3
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Postovi: 1,163
ne, kad odem tamo gdje si reko,nemam opće izbor taj foreign..
pristupam mu tako da odem u my computer i otvorim ga.
Ali sad ga neće otvorit i izbaci poruku disk nije formatiran oćeš to sad napravit.
to se poajvilo nakon što sam ga vratio u ladicu poslje onog od 4gb.
do tad je radio ok
