Lokacija: Lošinj
Postovi: 14
Gigabyte GA-M57SLI-S4 + AMD Phenom 7850 BE problem
Kupio sam AMD-ov procesor 7850 BE i pokušao ga instalirati na AM2(gore navedenu ploču). Instalirao sam novi bios, namazao pastu, namjestio hladnjak...al komp se s novi procem ne diže, ne mogu doći ni do bios-a...kad vratim stari proc(3600X2) sve radi bez problema....napajanje je fortron blue storm 2(500W), dotična matična navodno podržava naveden proc... Ako bilo tko ima ikakav savjet...pliz help!!! |
Postovi: 7,568
Sudeći prema onome kaj se da naći na službenim stranicama, jedini Athlon iz 7000 serije koju ta ploča (i to samo u reviziji 2.0) podržava je Athlon 7750. Ostali Kuma Athloni se uopće ne spominju. Sad ili ti imaš krivu reviziju ploče ili je Gigabyte zaljučil da ta starija AM2 SLi ploča nije vrijedna truda oko nadogranje BIOS-a za novije Athlone. |
Postovi: 7,568
Da trebala bi, ali ko zna zbog čega ti 7850 ne radi s tom pločom kak spada. |
Lokacija: Lošinj
Postovi: 14
i have been having problems clocking my 7850 BE and wondered if anyone has any suggestions. the cpu is running in my gigabyte ga-m57sli-s4 motherboard. i contacted gigabyte before i bought the cpu as it only showed the 7750 in there cpu support list, gigabyte then said it was supported and gave me the latest bios. i had to manually set the cpu voltage to 1.2v as the board wanted to run at 1.325v on auto. the cpu runs fine at 2.8ghz and with the voltage set to 1.2v but if i adjust the clock multiplier ever to 2.9ghz i will get a blue screen. if i set the voltage to 1.25v and set to 2.9ghz the pc will boot and go into windows, but i know straight away the pc isnt liking it as my mouse pointer becomes a white pointer instead of the usual gold colour. if i then try to run 3dmark it will lock up. has anyone got any idea of why this isnt overclocking even by this small amount. thanks in advance for any replies." Ovom liku očito radi...sad, po ovome ispada da treba smanjiti voltažu cpu-a na 1,2 pa bi stvar trebala biti stabilna...valjda...? |
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
lijepo se rjesis te ploce (znam da ju je lako prodati, bratic je se rjesavao neki dan i valjda isti dan kad je stavio u plavi oglas ju je prodao za nekih 250kn) i nabavis nesto novije sa sigurnom podrskom za nove procesore. Vjerovatno za istu lovu. Ne mogu reci da je trznica bas nesto prepuna AM2 ploca ali pojavi se tu i tamo nesto. |
