life is a rollercoaster..
Datum registracije: Dec 2003
Lokacija: Sl Brod
Postovi: 554
The Sims problem
Imam problem pri instalaciji Simsa na winxp (don`t laugh!) 16 bit windows subsystem C:\Windows\system32\autoexec.nt. The system file is not suitable for running MS-DOS and Microsoft windows applications. Choose "close" to terminate the application. Eto, to je greska koju mi javlja, ne znam sta da radim, na drugom kompu sve radi bez problema... Windowsi su clean install, bez SP-ova... Je li to do proca, jer je 64-bitni? |
Sannin
Datum registracije: Jun 2003
Postovi: 1,568
YES - BUT / your evaluation is superb - behold the underlying truth |
