Datum registracije: Jul 2009
Lokacija: N/A
Postovi: 2
![]() Pozdrav, CPU: i7 920 MOBO: Gigabyte EX58UD4 RAM: Corsair 3x2GB 1333 DDR3 - detalji u nastavku Nedavno sam uzeo Corsair 3x2GB kit DDD3 1333, nakon instalacije i boot-a POST screen je izbacio svih 6GB OK, BIOS također vidi svih 6GB ali prilikom provjere memorije pomoću CPU-Z i SiS Sandre na DMI read levelu nedostaje jedan stick. CPU-Z export (timing odrezan zbog dužine post-a): Memory SPD ------------------------------------------------------------------------------ DIMM #1 General Memory type DDR3 Module format UDIMM Manufacturer (ID) Corsair (7F7F9E0000000000) Size 2048 MBytes Max bandwidth PC3-10700H (667 MHz) Part number CM3X2G1333C9 Attributes Number of banks 8 Nominal Voltage 1.50 Volts EPP no XMP no DIMM #2 General Memory type DDR3 Module format UDIMM Manufacturer (ID) Corsair (7F7F9E0000000000) Size 2048 MBytes Max bandwidth PC3-10700H (667 MHz) Part number CM3X2G1333C9 Attributes Number of banks 8 Nominal Voltage 1.50 Volts EPP no XMP no DIMM #3 General Memory type DDR3 Module format UDIMM Manufacturer (ID) Corsair (7F7F9E0000000000) Size 2048 MBytes Max bandwidth PC3-10700H (667 MHz) Part number CM3X2G1333C9 Attributes Number of banks 8 Nominal Voltage 1.50 Volts EPP no XMP no ------------------------------------------------------------------------------------------------------------------------------ DMI Memory Controller --------------------- correction 8-bit parity Max module size 1024 MBytes DMI Memory Module ----------------- designation A0 size 2048 MBytes (single bank) DMI Memory Module ----------------- designation A1 DMI Memory Module ----------------- designation A2 size 2048 MBytes (single bank) DMI Memory Module ----------------- designation A3 DMI Memory Module ----------------- designation A4 DMI Memory Module ----------------- designation A5 ------------------------------------------------------------------------------------------------------------------------------------------- ...i konačno: DMI Physical Memory Array ------------------------- location Motherboard usage System Memory correction None max capacity 6144 MBytes max# of devices 6 DMI Memory Device ----------------- designation A0 format DIMM type unknown total width 2304 bits data width 2244 bits size 2048 MBytes DMI Memory Device ----------------- designation A1 format DIMM type unknown DMI Memory Device ----------------- designation A2 format DIMM type unknown total width 2304 bits data width 2244 bits size 2048 MBytes DMI Memory Device ----------------- designation A3 format DIMM type unknown DMI Memory Device ----------------- designation A4 format DIMM type unknown DMI Memory Device ----------------- designation A5 format DIMM type unknown ----------------------------------------------------------------------------------------------------------------------------------------- Kao što se može vidjeti, na SPD levelu je se OK ali na DMI fali jedan stick. Isto očitava i SiS Sandra: ![]() Na memory controler tab-u fali jedan stick. Napomenio bih da Windows task manager vidi i koristi svih 6GB kao i main screen u CPU-Z koji ne pokazuje nikakve devijacije: ![]() Zaključno, devijacije se vide u detail exportu i CPU-Z i SiS Sandri na DMI očitanjima, sve drugo ne odstupa od normalnog. Bio bih zahvalan kada bi netko prokomentirao rezultate i dao mišljenje o uzroku devijacija (možda neispravan memory controller na procesoru ali ne bih htio ništa sugerirati). Naravno, da nisam imao viška vremena i radio exporte i kopao ne bih ništa primjetio obzirom da task manager i CPU-Z ne očitavaju nepravilnosti u standardnom view-u i kanta radi stabilno , proklete moderne teNhnologije. Btw, ovo bi mogao biti problem dokazati u procesu garancije. ![]() Hvala unaprijed |
Lokacija: N/A
Postovi: 2
Problem riješen. ![]() Flash BIOS-a. Eto quick fix za korisnike Gigabyte EX58 serije ploča ako se nađu u sličnoj situaciji. Close thread... |
