Postovi: 16
Ne mogu se spojiti na internet!
Laptop je novi, ima Vistu, doma se bez problema spaja na internet (bežično), međutim na poslu neće nikako. Naravno, prvo šta mi pada na pamet je router, ali još 2 kompa (žičano) i jedan laptop (bežično) su spojeni na njega i rade bez problema. Da napomenem, kad ga spojim žičano, odmah se poveže.. evo šta izbaci: Host Name . . . . . . . . . . . . : Tanja-PC-Satellite Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Wireless LAN adapter s&t-wlan: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Atheros AR9281 Wireless Network Adapter Physical Address. . . . . . . . . : 00-24-D2-0F-2F-EC DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Ethernet adapter Local Area Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Realtek RTL8102E Family PCI-E Fast Ethernet NIC (NDIS 6.0) Physical Address. . . . . . . . . : 00-23-5A-05-FC-EA DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 6: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : isatap.{5BBC7BF5-429C-4455-B7B9-3461A3EE1D6} Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 7: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : isatap.{512DDB0E-907C-4EAA-A8EF-8D2CC290EF1} Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 11: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Physical Address. . . . . . . . . : 02-00-54-55-4E-01 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes MOLIM POMOĆ!!! ![]() |
Postovi: 12,613
Premalo podataka. Dali vidis SSID? Enkripcija?
Postovi: 16
Postovi: 12,613
Postovi: 16
traži mi security key, pokušava se spojit 10-ak sekundi i onda mi kaže da se ne može spojit.. stvar je u tome šta uopće ne uspostavlja vezu s routerom.. kad probam ping, dobijem sent 4, received 0, lost 4 (100% loss) error code 1231 |
Postovi: 23,535
Pa normalno da je sent/received 4/0 kad se wireless kartica nije spojila s routerom. Pretpostavljam da znaš / imaš ispravni wireless pass i da ga upisuješ u polje kad te pita? Ako je tako probaj slijedeće: 1. Na kompu koji je lanom spojen na router, otvori web konfig i ugasi zaštitu wirelessa + Reboot 2. Sada sa tim "spornim" lapom ćeš se moći spojit 3. Na kompu koji je lanom spojen na router, otvori web konfig i upali zaštitu wirelessa 4. Sada sa tim "spornim" lapom će te pitat za šifru wirelessa, unesi je i spojit će se. |
#7 | |
Postovi: 16
budući da nisam baš stručnjak, možeš li malo detaljnije opisat postupak??? ![]() EDIT: ne uspijeva, čim ponovo upalim zaštitu wirelessa, na laptopu se gasi internet ![]() Zadnje izmijenjeno od: domy_os. 17.07.2009. u 00:51. |
Postovi: 1,679
Postovi: 16
Postovi: 1,679
Postovi: 16
Postovi: 1,679
Postovi: 18,862
A onda otvori preffered networks, obriši taj router na koji se spajaš i pokušaj se ponovo spojiti. Ovaj puta bi te trebao pitati za lozinku jer je više "ne zna"...
