Staro 20.04.2009., 17:48   #1
Red_Baron
Datum registracije: Nov 2002
Postovi: 188
(riješeno) ASUS P5B-E Plus
Pozdrav,
nisam mogao upaliti računalo, isprovao sam sve komponente s cimerovim i zaključio da ne radi matična (gigabyte ds4). Kupio sam novu-used (u naslovu) u linksa. Pospojio sve komponente i ne pali. LEDica koja se nalazi na matičnoj ne svijetli konstantno već blinka. Isprovao sam s drugim napajanjem - ne radi. Svoj proc i svoje napajanje sam spajao na drugu ploču koja je uredno palila. Može li biti do napajanja (Fortron 400W), procesora (Intel Core2Duo E6300).
Što se tiče harwerskih kombinacija stvarno sam sve isprovao, jedino je HD bio uključen stalno, ali mislim da stvarno ne smeta
Molim pomoć da mi ne istekne rok za povrat ove matične ako i ona ne radi
Red_Baron je offline   Reply With Quote
Staro 20.04.2009., 17:59   #2
Zmalamuth
Inquisitor DeathWatch
Zmalamuth's Avatar
Lokacija: Zagreb-Rijeka
Postovi: 918
Ja imam doticnu Maticnu i Ledica koja osvjetljava "ASUS" mora goriti cijelo vrijeme, nesmije blinkat.
Moguce da je pokvarena, eventualno pogledaj u manual ili na net, sta znaci ako blinka.
Izgleda da je netko krivo/ lose Flashao Maticnu.
http://www.techsupportforum.com/hard...5b-e-plus.html
HI
THIS ISSUE IS FOR THE P5B-E PLUS MOTHERBOARD. THANKS
I have an issue with my motherboard P5B-E PLUS.
The problem appeared when i was flashing my bios via the ASUS Update on
windows.With the beta 0633
An error came to do with the Erasing EPPROM and after it stated if i would like to try
again or exit .
So i exit restarted the comp and my problem is that it doesn't Load and Nothing shows
up in to the screen.
I tryed all the steps on the manual and as well on the troubleshooting in asus
webpage.
I remove the battery.
Clear CMOS.
Unplugged all cables.
Tryed to load only 1 mem stick , cpu and vga only and it still persist.
NO beeps.
Just Stops before post.
It Detects my cd/dvd rom.
I have one disk that came with the motherboard but as well is not helpful.
I tryed to use the disk for the CrashFree Bios 3. But i think is not that disk.
So now basically i don't know what to do anymore.
I believe the Bios is corrupt because of the Flash Error.
Just to advise that it's not the 1st time i flush a bios in Windows with ASus Update.
SO know i don´t what to do i think i just need to correct the corrupt bios but how.
Best Regards
Iben C.
i7 4770K cooled by Noctua NH-D14
Asus Sabertooth Z87
Corsair Vengeance Pro 2x8Gb 1866Mhz
EVGA GTX 1080 - 8gb -FTW GAMING
Logitech G500 & G510 Keyboard
OCZ Vertex4 256gb/Samsung SSD 850 Evo 500G /640Gb WD Black/2TB WD Black/3x2TB WD in sharkoon docking station
LG GH22
Corsair HX620W
Corsair Carbide 678c
Arctic Bionix F140mm x3
Phillips Brilliance 240PW - 24'''
Zmalamuth je offline   Reply With Quote
Staro 24.04.2009., 13:34   #3
Red_Baron
Postovi: 188
Odnešen je na servis.
Hvala!
Staro 27.04.2009., 20:59   #4
Red_Baron
Postovi: 188
S prednje strane kučišta je otpala jedna plastika od USB konektora, to je očito radilo nekakav kratak spoj i matična je "blinkala", ako taj konektor isključim s matične sve je uredu i matična pali.
To sam sve morao ponovno isprobati i na staroj matičnoj (u nadi da ona ipak ne radi ) i fan od procesora se zavrti jednom pa stane i na taj način "radi", ne znam u čemu je sad problem.
Eto nadam se da sad svi sa sličnim problemom neće odmah nosit matičnu na servise
