Postovi: 126
... sa workgrupe na domenu...
imam problem. nece mi se komp spojit na domenu. ostali strojevi se spajajau bez problema, a ovaj javlja slijedecu gesku: The domain name MAIN might be a NetBIOS domain name. If this is the case, verify that the domain name is properly registered with WINS. If you are certain that the name is not a NetBIOS domain name, then the following information can help you troubleshoot your DNS configuration. The following error occurred when DNS was queried for the service location (SRV) resource record used to locate a domain controller for domain MAIN: The error was: "DNS name does not exist." (error code 0x0000232B RCODE_NAME_ERROR) The query was for the SRV record for _ldap._tcp.dc._msdcs.MAIN Common causes of this error include the following: - The DNS SRV record is not registered in DNS. - One or more of the following zones do not include delegation to its child zone: MAIN . (the root zone) For information about correcting this problem, click Help. sta napraviti?? |
Postovi: 126
rijeseno |
Resistance is futile
Postovi: 1,212
pa i mogo si ukratko opisat kak si rijesio...ak neko bude imo slicnih prob ![]() |
