Staro 24.02.2009., 13:03   #1
thorgir
Postovi: 21
Pržilica "ruši" PC
Bok svima,
imam problem već par dana,pržili mi ruši pc.
Konfiguracija:
AMD Athlon m2 3800+,Gigabyte Ga-M55S3 matična,4gb rama,Maxtor320gb,
Ati Radeon X1550,
1 IDE pržilica Plextor PX-740-A,master i Pioneer DVR-112 koji radi probleme.
Čim se ladica otvori ili umetne dvd pojavi se blue screen
Code:
http://i108.photobucket.com/albums/n7/thorgir99/crash.jpg
Instalirao zam zadnje drivere i one starije prije toga,isprobao i na XP-u i Visti,izvadio sam pržilicu i na iste konektore spojio hard disc i radi bez problema.
Pržilicu sam spojio externo i ispravna je,radi normalno!Nije mi jasno u čemu je problem?!Imate neko rješenje?
Unaprijed hvala!
thorgir je offline   Reply With Quote
Staro 24.02.2009., 13:49   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
A jesu ti podešene pržilice jedna na masetr a druga na slave na pinovima. Ili obe na CS barem.
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 24.02.2009., 13:58   #3
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,254
probaj vidjet dal ti je u biosu taj kanal podesen na "auto",
mozes jos probat zamjenit ide kabel za svaki slucaj, iako si rekao da hdd radi, al nista te ne kosta
Staro 24.02.2009., 15:10   #4
thorgir
Postovi: 21
Autor Čuks Pregled postova
Sorry nisam baš vičan izmjenama u biosu,možeš mi malo opširnije objasniti?
Plextor-ide je namješten u biosu kao master i radi normalno.
Druga pržilica koja radi probleme-Pioneer je isto kao i hard sata2.
Staro 24.02.2009., 15:59   #5
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,254
Autor thorgir Pregled postova
udes u bios, i tamo di se rikta sat i datum imas opcije da riktas u kojem modu da ti rade hardovi, optika,...
najbolje bi bilo da to sve bude na "auto" modu
takodjer kolega mortal ti je rekao da stavis jednu przu na master a drugu na slave ukoliko nije tako, ili bar na cable select
i kao zadnje mozes pokusat promjenit ide kabel tak da si 100& siguran
btw, sto se tice biosa bilo bi ti jasnije da procitas manual od ploce
Staro 24.02.2009., 17:49   #6
thorgir
Postovi: 21
kad dođem doma s posla budem isprobao,ali mi nije jasno ako je 1,5 godinu sve ok radilo otkud sad ovo problemi?!
Staro 24.02.2009., 17:51   #7
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,254
jebga, desava se,
ako nakraju nis od tog ne proradi probaj kod nekog frenda ustekat przu u komp pa vidi dal radi, i jos bi ju mogo probat spojit kod sebe na prvi ide kanal da vidis dal na njemu radi
Staro 24.02.2009., 18:10   #8
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
tako je i meni nedavno pocela zajebavati prza, isto sata. Bemti budalu koja kupi sata przilicu a istovremeno svima drugima savjetuje da od toga bjeze
Sta joj je bilo nemam ideje, ionako sam win mislio reinstalirati a poslije toga nije vise zajebavala. Bit ce da je nesto softverski (zakljuci on mudro )
