Staro 23.10.2004., 01:46   #1
fanatic4cs
fanatic4cs's Avatar
Lokacija: Pozarevac
Postovi: 26
Question S-ata hard
Kako da instaliram win xp na sata disk? Ubacim disk i digne win i kada trebam da stisnem f6 (trebam li?) on nista i stiskam i stiskam i nista ? Sta da radim!!!! :confused:
Asus A7N8X-E Delux ,Barton 2500+ ,Kingstone 2X256 + 512 ,asus Fx-5900 ultra ,2X200 gb Samsung sata ,Plextor dvd-rw ,Kworld tvr-pvr tv kard ,Sky star 2
fanatic4cs je offline   Reply With Quote
Staro 23.10.2004., 02:12   #2
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
ubaci disketu sa sata driverima koju si trebao dobiti uz plocu
mozes i integrirat sata driver u winxp instalaciju
Veky je offline   Reply With Quote
Staro 23.10.2004., 02:29   #3
fanatic4cs
fanatic4cs's Avatar
Lokacija: Pozarevac
Postovi: 26
kako
dobio sam cd ali ne flopi a kako da integrisem u xp?:burn:
Staro 23.10.2004., 12:17   #4
Veky
Veky's Avatar
Postovi: 1,950
http://www.google.com/search?sourcei...ata+windows+xp - google sve nadje
ovo su upute za si3112a
1) copy all the files from your XP cd to a temporary folder (let's call it C:\XPSource)
5) make a directory under C:\XPCD named $OEM$
6) make a directory under that called $1
7) make yet another directory under that called Drivers. you should now have something like C:\XPCD\$OEM$\$1\Drivers
9) download the newest SATA RAID drivers from SI. as of this post, you can get them here.
10) extract the "Si3112r.sys" file into the i386 folder (C:\XPCD\i386\Si3112r.sys)
11) extract the whole SATA driver archive (all the files) to a directory under Drivers, say C:\XPCD\$OEM$\$1\Drivers\SATA.
12) find the TXTSETUP.SIF file in the i386 folder (C:\XPCD\i386\TXTSETUP.SIF) and open it in NOTEPAD.
13) add the following line under [SourceDisksFiles]
si3112r.sys = 1,,,,,,_x,4,1
14) add the following line under [HardwareIdsDatabase]
PCI\VEN_1095&DEV_3112&SUBSYS_61121095 = "Si3112r"
15) add the following line under [SCSI.Load]
si3112r = si3112r.sys,4
16) add the following line under [SCSI]
si3112r = "Silicon Image SiI 3112 SATARaid Controller"
17) save your changes to TXTSETUP.SIF - we're done with this file. this file is for the text-based portion of the install (before we get XP's GUI). it keeps us from having to insert a floppy and pressing F6 during setup.
23) burn it to a bootable CD by following the guide here: http://www.tacktech.com/display.cfm?...cle.cfm&id=160
Staro 25.10.2004., 23:11   #5
No123
Lokacija: Grad na Dravi
Postovi: 580
Re: kako
Onda na CD-u imas MakeDisk, ubaci prazan flopy i klikni na MakeDisk i napravit ce ti disketu pa onda kada stisnes F6 odmah ubaci tu disketu i sve ce proci dobro
No123 je offline   Reply With Quote
Staro 31.10.2004., 17:33   #6
Emissary
ČLAN FKTa
Emissary's Avatar
Datum registracije: Jul 2004
Postovi: 2,264
Je li zna ko koji je SATA čip na ASUS A7V600, odnosno koji je proizvođač dotičnog???
Je li to onaj čip na kojem piše ITE?
Molim vas za brzu pomoć, držim Windowse na Quantumu od 5GB, a CARNet mi ističe 1.11. tj. u ponoć, pa da stignem downloadat driver za SATA.
HELP!!!
P.S. Čipset je Via KT600+VT8237.
Staro 31.10.2004., 18:03   #7
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
RAID je od VIA-e, integriran u southbridge , skini s njihovih stranica...
Staro 31.10.2004., 18:16   #8
Emissary
ČLAN FKTa
Emissary's Avatar
Postovi: 2,264
Ma meni samo treba prepoznavanje SATA harda od strane Windowsa XP professional
Na viaarena.com je RAID driver od 6.5MB, jel možda toga trebam skinut, i onda kad otpakiram, samo stavim neke fileove na disketu, i srisnem F6 pri instalaciji ili:confused:
Staro 31.10.2004., 18:18   #9
CatKiller
CatKiller's Avatar
Postovi: 3,312
Da to je to, imaš unutra folder "Driver Disk" , tako nekako, samo si ga skopiraj na disketu, dalje znaš...
Staro 31.10.2004., 18:32   #10
Emissary
ČLAN FKTa
Emissary's Avatar
Postovi: 2,264
TNX Cat, evo već skidam
BTW, jel znaš ti slučajno za kakav modani bios za ovu ploču?
Slabi su naponi, a napon čipseta se ne može povećat, a ploča neće preko 220 (ili je možda Corsair Value u qrcu)
Staro 31.10.2004., 21:08   #11
MentalHarikiri
MentalHarikiri's Avatar
Postovi: 2,560
VIA KT600 nema PCI/AGP lock
Staro 31.10.2004., 21:09   #12
Vedran
Vedran's Avatar
Lokacija: Kutina
Postovi: 1,208
kt600 nema agp/pci lock koliko ja znam, zato baš i nije jak oc-er...
Vedran je offline   Reply With Quote
Staro 31.10.2004., 21:11   #13
Vedran
Vedran's Avatar
Lokacija: Kutina
Postovi: 1,208
ups... sorry mental što te ponavljam, tvoj post je uletio dok sam tipkao svoj...
Staro 31.10.2004., 21:57   #14
Emissary
ČLAN FKTa
Emissary's Avatar
Postovi: 2,264
Ma znam da nema lock, ali zar je tome prokletom southbridgeu tako teško izdržat 5MHz više
Dobro bi mi došao modani bios upravo radi povećanja napona, još koji megajerc FSBa i malo smanjit latencije meme i kud ćeš bolje.
Anyway, SATA i Windowsi su pronašli zajednički jezik, tako da častim pivom
Staro 01.11.2004., 11:39   #15
Vedran
Vedran's Avatar
Lokacija: Kutina
Postovi: 1,208
koje veze ima southbridge s oc-om? :confused:
