Staro 06.01.2009., 21:46   #1
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
(riješeno) Pila od štila se ne gasi
Dakle skrpao sam staru zvijer i imam problem.
http://forum.pcekspert.com/showthread.php?t=133042
Naime komp normalno ugasim na shutdown u WinXP, ali pila i dalje radi, svijetli zelena LEDica i svi ventovi se vrte, kao da je nešto enejblano u BIOSu, a ja se više ne sjećam što bi to moglo biti, jebiga...ako netko zna nek pomogne
Da nije nešto od ovoga iz PowerManagement dijela AMI BIOS-a? Meni je po defaultu APM/ACPI enejblan.
Power Management Setup Page
This page sets some of the parameters for system power management operation.
AMIBIOS SETUP – POWER MANAGEMENT SETUP
©1998 American Megatrends, Inc. All Rights Reserved
Power Management/APM Disabled
Standby Time Out (Minute) Disabled
Suspend Time Out (Minute) Disabled
Ring On Power On Disabled
LAN Card Power On Disabled
RTC Alarm Power On Disabled
RTC Alarm Date 15
RTC Alarm Hour 12
RTC Alarm Minute 30
RTC Alarm Second 30
ESC : Quit  : Select Item
F1 : Help PU/PD/+/- : Modify
F5 : Old Values (Shift)F2 : Color
F6 : Load Optimal values
F7 : Load Best performance values
Power Management/APM Use this item to enable or disable a power management scheme. If you enable power management, you can use the items below to set the power management operation. Both APM and ACPI are supported.
Standby Time Out (Minute) This sets the timeout for Standby mode in minutes. If the time selected passes without any system activity, the computer will enter power-saving Standby mode.
Suspend Time Out (Minute) This sets the timeout for Suspend mode in minutes. If the time selected passes without any system activity, the computer will enter power-saving Suspend mode.
Ring On Power On The system can be turned off with a software command. If you enable this item, the system can automatically resume if there is an incoming call on the Fax/Modem. You must use an ATX power supply in order to use this feature.
LAN Card Power On The system can be turned off with a software command. If you enable this item, the system can automatically resume if there is traffic on the network adapter. You must use an ATX power supply in order to use this feature.
RTC Alarm Power On The system can be turned off with a software command. If you enable this item, the system can automatically resume at a fixed time based on the system’s RTC (realtime clock). Use the items below this one to set the date and time of the wake-up alarm. You must use an ATX power supply in order to use this feature.
Staro 06.01.2009., 22:57   #2
thopok
Lokacija: Splity
Postovi: 3,003
Staro 06.01.2009., 23:35   #3
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,577
probaj ovo
Open Control Panel > System > Hardware > System > Device Manager > Computer> Standard PC > Driver > Update Driver... > No, not this time... > Next > Install from a list or specific location (Advanced) > Don't search. I will choose the driver to install. > Next > ACPI Uniprocessor PC...
T0mB1ll je offline   Reply With Quote
Staro 06.01.2009., 23:36   #4
skydec
Lokacija: Koprivnica
Postovi: 120
Možda imaš u biosu opciju AT/ATX koja je postavljena na AT.
skydec je offline   Reply With Quote
Staro 10.01.2009., 00:17   #5
jeremija123
Lokacija: Derventa
Postovi: 3
Naletio sam na tu ploču prije par godina.Donio mi prijatelj da mu sredim comp, hoće dijete da se igra.Instalirao XP i ostalo, Max Payne čak radi na tom aladinu.Nazovem i kažem da dođe po svoj krš, sve radi ok.Onda shut down i k****.Nema šta nisam probao u Biosu i opcijama napajanja, googlao, instalirao update, nema šanse da se ugasi PCCHIPS i kikiriki.Oko 4 ujutro instaliram Win98 i završim stvar.Tako da je to jedina šansa ako hoćeš da ne gasiš comp na dugme.
jeremija123 je offline   Reply With Quote
Staro 10.01.2009., 01:04   #6
Postovi: 23,643
Nađi na netu SHUTDOWN.EXE i probaj da li će se ugasit (vidi switcheve).
Ako to radi, treba iskopat kako u registry - ju zamjenit standardnu shutdown komandu.
Staro 10.01.2009., 10:50   #7
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ipak je proradilo, ne znam ni sam kako, instalacijom svih drivera uključujući i Detonatora 21 za Aladina TNT2 i onih za integrirani 56k modem kojeg više nitko ne koristi. I dalje nema stby opciju kod shutdowm menija, ali se barem ugasi da ne moram razmišljati o prekidaču
Daklem, ipak radi pod WinXP Problem riješen.
Staro 13.03.2015., 13:25   #8
Mikael10
Datum registracije: Mar 2015
Postovi: 7
Pozdrav, mozda kriva tema, al me zanima..
jel ima kakva mogucnost da kada zatvorim laptop da dalje radi , ali slika da je prenesena na TV (HDMI kablom) ? Hvala
p.s. dobil nekvo rjesenje, pronasao sam ovo rjesenje; green it
Zadnje izmijenjeno od: Mikael10. 16.03.2015. u 09:58.
Mikael10 je offline   Reply With Quote
Staro 14.03.2015., 14:00   #9
nino_z
nino_z's Avatar
Lokacija: Valpovo/Osijek
Postovi: 267
nino_z je offline   Reply With Quote
