Staro 20.12.2008., 01:18   #1
p4wner
p4wner's Avatar
Lokacija: Ivankovo
Postovi: 12
Uključivanje
POzdrav ljudi hitno trebam pomoc...prijatelj je kupio par novih dijelova i sad imamo problem...sve je slozeno pospajano pravilno i problem je sljedeci da kad upali komp on samo zuji i nista se vise nedesava...dijelovi su sljedeci...
Asrock nforce 3 250 ima pcie i agp ulaz....
Amd athlon 64 x2 5600+
2x2gb ddr2 pc6400 800mhz kingmax
Ati Sapphire x1950pro 512 mb agp...
OCZ power StealthXStream 500W...
Kada stisnem tipku za paljenje on se kao pocme paliti bude crna slika na monitoru i onda se nakon 1 minute monitor ugasi(tj kao da je na stand by-u) i sve tako stoji...HELP PLSS!!!
p4wner je offline   Reply With Quote
Staro 20.12.2008., 01:45   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
1. Izvadi bateriju i ponovo stavi.
2. Stavi ramove u drugi slot ili samo jedan ram stavi da eliminiraš to.
3. COld boot dakle ne slaganje ploče sa napajanjem ( NF3 i NF4 čipseti)
Čekaj nforce 3 i ddr2?
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 20.12.2008., 02:04   #3
p4wner
p4wner's Avatar
Lokacija: Ivankovo
Postovi: 12
Maticna je ova:
http://www.hgspot.hr/opis.aspx?ID=032676
neznam zasto nebi odgovarala sa ramima??
Staro 20.12.2008., 02:59   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Možda si dobio neispavni ram, možda si dobio neispravnu ploču....
Ne mora sve kupljenu u dućanu bit ispravno
Ali koliko se sjećam bilo je nekompatibilnosti x1950 agp sa nf3 čipsetima
Ryzen 7 2700X
2x 8gb Crucial
B450 Aurus Elite
GTX 1060
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
Harman Kardon
MX revolution
Battery grip
Sony: 18-70, 55-200
Staro 20.12.2008., 03:47   #5
Valg
Lokacija: City
Postovi: 1,404
Hmmm malo kinki...
Za početak, posudi PCI-E grafu, pa da vidiš dali radi...
Ako radi, u BIOS-u podesi AGP za first boot, jer i prilikom CMOS-a zna se desiti da neće prebaciti na AGP...
Ali naravno, resetiraj bios, pa probaj...
Valg je offline   Reply With Quote
Staro 20.12.2008., 10:42   #6
Steve
Lokacija: Ivankovo
Postovi: 1
evo i ja sam se registriro da ne moram stalno njemu govorit sta da posta.. izvadio sam bateriju iz maticne i vratio, i premjestio sam rame u druga 2 slota i opet nista.. ne znam vise sta da mu radim.. jel ima mozda neko određeno vrijeme koje baterija mora biti vani kako bi se bio resetirao ?? ja sam ceko mozda 5 sek.. ipak, nestrpljiv sam..
Steve je offline   Reply With Quote
Staro 20.12.2008., 11:21   #7
Postovi: 34,062
Čekaj više - bar 10 min.
Staro 20.12.2008., 11:48   #8
Daddy
The Kwisatz Moderach
Daddy's Avatar
Postovi: 921
Mozda je procesor prenov za verziju biosa na ploci.Ako imas mogucnosti nabaviti neki stariji jednojezgreni, probaj flashati zadnjim biosom i vidi da li igra kakvu ulogu.
Staro 20.12.2008., 17:04   #9
domy_os
domy_os's Avatar
Postovi: 18,940
Ta ploča je teški miks svega i svačega što inače nije međusobno službeno podržano. Ne bih se čudio da ona ne radi ili da radi samo s točno određenim komponentama. Isto tako je i za tu grafu bolje da bude PCI-E nego AGP...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 21.12.2008., 17:52   #10
Speedbreaker
Postovi: 545
probaj flešat bios.nhf, ali nebi se čudio da ti nikad ne proradi jer ta ploča ima previše novih sabirnica za čipset star 4-5 godina.najbolje bi ti bilo da kupiš neku poštenu ploču i grafu, a ovo staro prodaš.
Speedbreaker je offline   Reply With Quote
Staro 22.12.2008., 11:55   #11
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
nije toliko bitno sto je ploca stara, moze to na njoj raditi. Naravno update biosa bi bio pametan.
No za to mora prvo upaliti komp
Za pocetak, ja bi probao s drugom grafom. Po mogucnosti PCIe
Staro 22.12.2008., 13:08   #12
Valg
Lokacija: City
Postovi: 1,404
Jao, nemoj vaditi bateriju...
Nadalje, pošto imaš AMD 5600+, onda je to AM2+ ploča, jer postoji i 939 revizija, al mala je razlika...
Isključi kabal od napajanja, baterija na ploči mora ostati, i onda oaj jumper prespoji na susjedni pin:
[OO]O -> Postavke "pamćenja bios-a"
O[OO] -> Postavke "izbrisavanja" bios-a i postavljanje na tvorničke postavke...
I evo slika da nebi bilo nismo znali:
Evo da vidiš gdje je to, da se ne izgubiš:
I da, prebaci jumper na min 5 sekundi (10 strojnih ciklusa), te ga vrati prije uključivanja, nebi trebao ostati na mjestu za brisanje, kod starijih ploča zna doći do trajnog oštećenja bios-a...
I opet ti napominjem: baterija na ploči, ali kabal od napajanja isključen...
Sretno...
EDIT:
http://my.ocworkbench.com/bbs/showthread.php?t=69402
