Staro 28.09.2004., 13:47   #1
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,097
FC i OGL renderer ...
Cisto me zanima da li je neko to probao ili cu ja biti prvi:
Copy/Paste sa tweakguides.com
FarCryConfigurator.exe
Texture Filter Quality
GL_TextureFilter [GL_LINEAR_MIPMAP_NEAREST, GL_LINEAR_MIPMAP_LINEAR] - If you are using the OpenGL renderer (See System.cfg in Advanced Tweaking Section) then GL_LINEAR_MIPMAP_NEAREST=Bilinear Filtering, and GL_LINEAR_MIPMAP_LINEAR=Trilinear Filtering under OpenGL. Similar performance impacts as described above.
Za System.cfg i Systemcfgoverride.cfg
r_Driver [OpenGL, Direct3D9] - OpenGL=Use OpenGL renderer. Direct3D9=Use default DirectX9.0 renderer. Setting the renderer to OpenGL may resolve problems and improve performance for some users, especially Nvidia graphics card owners. If you experience problems revert back to the default Direct3D9 renderer for optimal stability/compatibility.
Sto cu kad nemam DX9 karticu
Verifikacija poštenog trgovca #1, #2, #3, #4, #5, #6, #7, #8, #9
Staro 28.09.2004., 17:54   #2
dr.fiksi
doktor, trekkie, amd-ovac
dr.fiksi's Avatar
Postovi: 1,043
Ja sam probao OGL renderer, kao što vidiš-nije zbog hardvera nego iz znatiželje.
Samo sam nabrzinu pokrenuo...nisam ništa posebno vidio drukčije, a framerate nisma mjerio.
Svijet je monitor s beskonačnom rezolucijom!
1.a64 3500+,abit av8,1.5gb corsair, leadtek geforce 6800 ultra,2x200gb seagate@raid 0,tagan 480w...
2.mobilac 2600+ na 2332mhz,epox 8rda3i,r9800pro,120gb,512ddr,ener 350w...
3.MSI centrino 1.5(dothan), ati9600,40gb...
-->HDD u externom kućištu USB 2.0+firewire-hitachi 200 giga
dr.fiksi je offline   Reply With Quote
Staro 29.09.2004., 09:26   #3
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,097
Ja sam ga isto prebacio na OpenGL, ali sam i "Texture quality" prebacio na High. Sad je to puno bolje. Zapravo na DX nisam niti probavao mijenjati kvalitetu tekstura.
