Staro 06.11.2008., 23:43   #1
Linkhr
Datum registracije: Apr 2008
Lokacija: Mars
Postovi: 41
Problem sa ata hdd-om
Evo ovako imam Windows Vista 64-bit i WD Sata hdd od 80 gb. uz njega sam si nabavio jos jedan WD 80 gb ali ata. I kada ga ubacim BIOS ga ocita ali ga ne ocitavaju windowsi! Probao sam sve kombinacije (master, slave, ...) i nista. U cem bi mogao biti problem
Linkhr je offline   Reply With Quote
Staro 07.11.2008., 02:45   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
Desni klik na my computer pa na manage,pod disk managment nades svoj drugi disk i formatiras radis s njim sta hoces..Npr. pogledaj tu RAK-ov vodic (samo sta je ovo pisano za XP,ali princip je isti) http://forum.pcekspert.com/showthread.php?t=99054
IE6
Linux is Not Windows
Staro 07.11.2008., 02:48   #3
thopok
Lokacija: Splity
Postovi: 3,003
Install or remove a hard disk drive
Preparing to use a new hard disk
If you plan to use the new hard disk as a secondary disk (one that does not contain Windows), you should be able to see the new hard disk drive the next time you start your computer and log on to Windows.
If you don't see the new hard disk drive, try looking for it in Computer Management.
Staro 07.11.2008., 21:46   #4
Linkhr
Lokacija: Mars
Postovi: 41
Opet se javlja problem da mi ga ni tamo ne nalazi!
Staro 08.11.2008., 00:18   #5
thopok
Lokacija: Splity
Postovi: 3,003
If your drive is not detected by Windows XP or Windows Vista when you check in Disk Management, follow the steps below.
