Lokacija: Ribarska 29, 52203 Medulin, Hrvatska
Postovi: 225
Windows Update danas ne radi?
Windows Update mi danas ne radi, samo meni ili svima Molim nekoga da provjeri pa da se javi, znači kad kliknem na Windows update javi grešku: Connection Interrupted The connection to the server was reset while the page was loading. The network link was interrupted while negotiating a connection. Please try again. Pozdrav |
Lokacija: .com
Postovi: 519
Istina, ne radi ni meni? [Error number: 0x8DDD0018] The site cannot continue because one or more of these Windows services is not running:
1. Click Start, and then click Run. 2. Type services.msc and then click OK. 3. In the list of services, double-click on Automatic Updates and then click Properties. 4. In the Startup type list, select Automatic and click Apply. 5. Verify that the Service status is started, if the Service Status is Stopped click on the Start Button. 6. In the list of services, double-click on Background Intelligent Transfer Service (BITS) and then click Properties. 7. In the Startup type list, select Manual and click Apply. 8. Verify that the Service status is started, If the Service Status is Stopped click on the Start Button. 9. In the list of services, double-click on Event Log and then click Properties. 10. In the Startup type list, select Automatic and click Apply. 11. Verify that the Service status is started, If the Service Status is Stopped click on the Start Button. If this does not resolve the problem you may request help from one of the following resources. For self-help options:
Postovi: 1,505
Upravo provjerio Microsoft update i Windows update, sve radi. |
Lokacija: Splity
Postovi: 3,003
#5 | |
Postovi: 225
Ista stvar
Postovi: 225
Rješeno
Sad je sve OK Pristup Windows updateu mi je blokirao jedan izuzetno opasan rootkit pod imenom regx32 kojega nisu detektirali ni NOD32, ni Spyboot ni Spyware Doctor ni AdAware ni Superantispyware. Tek kad sam instalirao UnHackMe - on ga je prilikom bootanja blokirao i dao mi da ga izbrišem. Nakon toga sve mi je proradilo što je inače bilo sumnjivo - Windows update ili bilo koji link prema Microsoftu, razna updejtanja spy-programa itd... to niš prije nije radilo. Inače je ostalo na internetu radilo sve OK, samo tako neke stvari nisu bile u funkciji. Pozdrav |
